zoneMergeFailureIsolation - how to resolve?
mgodfrey
I'm trying to create an ISL between two MDS switches.  I got this error I haven't seen before: zoneMergeFailureIsolation
The only thing I found on this fault is: "The two Interconnect_Ports cannot merge zoning configuration after having exchanged merging request for zoning."
From that description I can't tell what needs to be changed or what is wrong?
Any ideas on how to resolve this issue?
Thanks.
Vu Phan
Hop into the switch that have the most zone members
ex: fcx/y is the interface of ISL
switch#  zoneset import interface fcx/y
switch# show int fcx/y
Kris Vandecruys
Hi Michael,
check if both ends are running the same zoning mode (basic vs enhanced) using the 'show zone status' command.  The second line per VSAN should be the mode and they should be equal on both ends per VSAN (can be different between vsans)
mgodfrey
Ok my issues is resloved.
I'm not sure what was the initial cause of the zoneMergeFailureIsolation.
Ended up clearing up one side of all zones/zonesets and then reconnecting the ISL and it seemed to work.
Tomas Mazur
I had this issue between MDS 9124e and Brocade 3900.
Originally we had only one MDS module which worked fine. After adding another MDS to the fabric and updating its zoneset with
"zoneset import interface interface-number vsan vsan-id" redundant card kicked in.
We also had to update NX-OS on the original MDS module and after restarting it all interfaces went into isolated mode.
Eventually I created new VSAN and moved all required interfaces to it. Zoneset populated automatically after few minutes we had full redundancy.
