CBS 350 switch functionality
srini mnc
Community Member
Can I use CBS350 switch as a core switch in a network,will it perform Layer 3 functions
 Yes, you can.
Advanced Layer 3 Traffic Management
The Cisco Business 350 Series Switches enable a more advanced set of traffic management capabilities to help growing businesses organize their networks more effectively and efficiently. For example, the switches provide dynamic Layer 3 routing, allowing you to segment your network into workgroups and communicate across VLANs without degrading application performance.
With these capabilities, you can boost the efficiency of your network by offloading internal traffic-handling tasks from your router and allowing it to manage primarily external traffic and security."
Jitendra Kumar
No Doubt you can use this Switch as a L3.
Below is the Feature link that you can check.
https://www.cisco.com/c/en/us/products/collateral/switches/business-350-series-managed-switches/datasheet-c78-744156.html
Jitendra
Jitendra
