09-23-2021 12:04 PM - edited 09-23-2021 12:36 PM
It seems "Idle Session Timeout" doesn't work for HTTP/HTTPS connections on CBS250 series switches?
(example from a CBS250-24P-4X)
Updating value via web interface doesn't affect 'running-config', and user sessions get terminated after about 5 minutes regardless what the setting is set to (via web interface).
After setting HTTP/HTTPS session timeout to 30 minutes, and logging out and logging back in (and clicking "Port Management"), and leaving browser window 'idle':
23-Sep-2021 11:41:07 %AAA-I-CONNECT: New http connection for user admin, source 172.16.1.42 destination 172.16.1.10 ACCEPTED 23-Sep-2021 11:47:57 %AAA-I-DISCONNECT: http connection for user admin, source 172.16.1.42 destination 172.16.1.10 TERMINATED
switch1#sh ver Active-image: flash://system/images/image_cbs250_ros_3.1.1.7_release_cisco_signed.bin Version: 3.1.1.7 MD5 Digest: 4805a22186295e82609a0a3e6def88e0 Date: 12-Aug-2021 Time: 15:02:37 Inactive-image: flash://system/images/image_cbs250_ros_3.1.0.57_release_cisco_signed.bin Version: 3.1.0.57 MD5 Digest: 9eac4c7725aaf03a8d8cfd1bf909edf3 Date: 18-Jan-2021 Time: 18:07:11 switch1#
Update:
Configuring timeout policy via CLI doesn't seem to have any effect either:
switch1#sh run | include ip http ip http timeout-policy 0 switch1#
Still getting disconnected in about 5-10 minutes:
23-Sep-2021 12:27:11 %AAA-I-CONNECT: New http connection for user admin, source 172.16.1.42 destination 172.16.1.10 ACCEPTED 23-Sep-2021 12:34:58 %AAA-I-DISCONNECT: http connection for user admin, source 172.16.1.42 destination 172.16.1.10 TERMINATED
12-22-2021 12:41 AM
Got the same problem. Were you able to resolve it somehow?
08-10-2023 08:12 AM
Couple of years later and just got a new Business 250 switch, and I have the same issue. I get logged out after only a few minutes even though it is set for 30 minutes.
Did you ever find a solution?
05-25-2025 07:54 AM - edited 05-25-2025 08:05 AM
I have the same problem here. I only get just a minute, although 30 minutes are set. very annoying.
25-May-2025 17:00:15 %AAA-I-CONNECT: New https connection for user admin, source 10.100.99.3 destination 10.100.1.250 ACCEPTED
25-May-2025 17:01:18 %AAA-I-DISCONNECT: https connection for user admin, source 10.100.99.3 destination 10.100.1.250 TERMINATED
has anyone found a solution or been able to ask Cisco support? my CBS 250 is no longer in support.
