1751 Basic Configuration required
chopra
At Present I am using No-name VOIP Routers and they are working fine. Now I want to replace them with Cisco Routers to get better results. I tried to configure them with Cisco "ConfigMaker" but I am facing lots of problem. I need help.
I need a basic Configurations:
Location-1:
Cisco 1751V Router, installed with WIC-1NET Card in Slot 0 and VIC-2FXO installed in Slot 1.
PPPoE Settings ( User Name: chopra Password: 123 Fixed IP Address: 82.x.x.6 Authentication protocol: pap)
Fixed IP Network Settings: ( IP Address 82.x.x.6 Subnet Mask: 255.0.0.0 Gateway IP address: 82.x.x.46 Pimary DNS Server: 81.x.x.1 Secondary DNS Server: 81.x.x.2)
PSTN: Country Code: 0049 Area Code: 2331 Phone Number: 400595 and 400596
Location-2: Cisco 1751 Router, installed with WIC-1NET Card in Slot 0 and VIC-2FXS installed in Slot 1.
Fixed IP Network Settings: ( IP Address 203.x.x.108 Subnet Mask: 255.255.255.0 Gateway IP address: 203.x.x.98 Pimary DNS Server: 203.x.x.98 Secondary DNS Server: 203.x.x.98 )
PSTN: Country Code: 0092 Area Code: 85 Phone Number: 77777777 and 88888888
I want to make calls from Location-2 to Location-1 in PSTN area and the calls from Location-1 should be diverted to Location-2.
Not applicable
