1841 - I can ping and tracert but not browse
patrsup
I am still working on the switching and routing at a small school. I have the 1841 hanging off port 48 on my 3750 switch and it connects to the router in port 1.
I am trying to get this 1841 to host several ubiquity access points and provide basic dhcp services. The 3750 is doing well with its setup I believe.
I have included the three configs i have.
Thanks in advance for your time
pat
No problem, glad to have helped.
Jon
64 Replies 64
Jon Marshall
Edit, can you just draw a quick diagram to show what you are trying to do.
Jon
patrsup
here is a quick sketch - Im on the road so it was done in a burger joint - sorry for the quality
Thanks for the diagram.
So on your 1841 you have a default route pointing out fa0 interface which has a 192.168.1.5 IP.
But both the 3750 and the 1900 router have an IP from this range as well.
In additon the 3750 is routing for another vlan ie. 53.
You are also doing NAT on the 1841 translating the 172.23.1.x IPs to 192.168.15  but then doing NAT on the 192.168.1.x IPs on the 1900.
So it is all a bit confused because you have extended one IP subnet between everything whilst at the same time you are routing different subnets on the 1841 and 3750.
I am still not sure why you need the 1841 unless you have run out of ports on the 3750 ie. why not just connect the APs to the 3750 as it is already routing anyway ?
Even if you keep the 1841 I can't see the point of doing NAT on that router.
Can you perhaps explain the reasoning behind it.
I'm not saying it is wrong but it might help me to provide a better answer to your question.
Jon
Jon,
Thanks for the questions, it illuminates my lack of knowledge on the lan setups - Here is what I need at a minimum
The 1900 for the connecton to charter. All it's supposed to do is provide the inside to the outside routing.
The 3750 is supposed to be a distribution switch and feeds several other smaller linksys routers supporting the back office and one in each of two computer labs. Additionally, it connects through a barracuda to 4 OLD cisco business switches which are unmanaged and really are acting as hubs.
I have two more 1900 series switches and 4 more 3750's which I could use to get the traffic off the old business switches and add seprate subnets for the wireless and the teachers computers which are on wired lan connections but I am not sure how to set them up at this point..
I have the entire school running off the 1900 and and the 3750 distribution switch. The wireless is currently hanging off it by 100 mp rj45 connections to two linksys routers supporting two school wide wireless networks on ubiquity accesspoints. I have to reboot these linksys routers about every 4 hours as they overheat and will not give out dhcp addresses nor route traffic.
The 1841 is an effort to replace these two linksys routers with one device and subnet.
I would like to have a setup with 5 individual subnets each /24 and the appropriate routing between the 3750's but that is outside my knowledge base at this point.
Hope this helps clear up what I have going on
pat
Are you able to ping 192.168.1.1 from 1841?
on 1841 configure these commands.
ip route 0.0.0.0 0.0.0.0 192.168.1.1
no ip route 0.0.0.0 0.0.0.0 FastEthernet0
no ip route 172.23.1.0 255.255.255.0 FastEthernet0
interface FastEthernet0
no ip nat outside
on 1900
interface GigabitEthernet0/1
no ip access-group incoming in
Please share the result.
Masoud
Thanks for clarifying.
I appreciate your initial post was about troubleshooting so I don't want to go off and redesign your network but I really don't think you need the 1841.
You could just use your existing 3750 and create a new vlan if you want for the APs.
You could then do all your routing between vlans on the 3750 and only send traffic to the 1900 for remote subnets.
Your 3750 will support routing between multiple vlans.
This would make your setup a lot simpler to manage as you go forward.
You could if you needed use one of your other 3750s as a L2 switch only for the AP connections and then simply connect to the L3 3750 you are currently using for the routing.
We can help you set all of that up although actually just to migrate the APs to the 3750 would be relatively trivial but if you also wanted to use more vlans/IP subnets we could help with that too.
Like I say though if you just want to troubleshoot what you have then we can help as well.
I still don't see a need to do NAT on the 1841 though.
Let us know what you want to do.
Jon
Jon,
Sounds like a lot of work for you but if you wanted to do the configs for the 1900 and two 3750's with 4 subnets (two each on the 3750's) I would be glad to toss the 1841. I need one of the subnets to remain 172.24.53.0 due to static ip's throughout the network but other than that they can be anything.
Thanks again
Pat
Pat
I was thinking of routing all the subnets on your existing 3750.
So you would replace the 1841 with one of your 3750s and then connect that to the existing 3750 with a trunk link.
You can connect your APs to the new 3750 and then create the L3 vlan interfaces on the 3750.
The subnets can use any addressing you want.
Does this sound okay ?
Jon
That would be fine -
Again, I think you for your help with this
Sorry one last question.
Are the 3750s you mentioned currently in use or is it a spare ?
If it is in use how it is connected currently ie. to what ?
And can you post a "sh vtp status" from your existing 3750.
I just want to make sure we don't mess up the vlan database on your existing switch.
If you confirm the above I can give you the steps you need to set it up.
I won't be around until later but I should be able to post this evening (UK time).
Let me know.
Jon
I have two spare 1941's and three spare 3750's so you can just make the configs how you want and I will put them on the spare equipment and then cutover when complete
Thanks again
Pat
Do you know if the APs need trunk connections or not ?
And can you post "sh vtp status" from your existing 3750.
Jon
XWALGOMA-Entrance#sho vtp status
VTP Version capable : 1 to 3
VTP version running : 1
VTP Domain Name : Algoma2
VTP Pruning Mode : Disabled
VTP Traps Generation : Disabled
Device ID : 0022.0d09.3c80
Configuration last modified by 0.0.0.0 at 0-0-00 00:00:00
Feature VLAN:
VTP Operating Mode : Transparent
Maximum VLANs supported locally : 1005
Number of existing VLANs : 9
Configuration Revision : 0
MD5 digest : 0xEC 0x1B 0xF6 0x60 0xAF 0x82 0x10 0x79
0xF9 0xCC 0x9D 0x16 0xED 0xE3 0x97 0xC9
XWALGOMA-Entrance#
Are you going to be doing this as we go along or in one big hit ?
And can you have any downtime ?
There are a couple of changes needed that may have a slight affect on the network ie a temporary outage of about 50 seconds no more.
If you want we can do it step by step as I am online for a while as you need to make changes to the existing 3750 (nothing major) and to the 1900 router (again nothing major).
Jon
