Showing results forĀ
Search instead forĀ
Did you mean:Ā
2620xm bootup loop
bustermark
Hello when I bootup my 2620xm I see this error over and over. I cannot put any commands in.
*Mar  1 00:26:46.963: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/help.cfg) failed
%Error opening tftp://255.255.255.255/help-confg (Timed out)
It does this forever... it never stops. Over and over again in my console.
Does my system have a bad IOS or bad ram?
Mark
Mahesh Gohil
Level 7
Level 7
Hello Marc,
From the error message i got below details. As suggested below can you go ahead with "no service config "
%SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from ([chars]) failed
The configuration file from the URL specified in the error message could not be read.
Recommended Action: Enter the no service config command to disable autoloading of configuration files OR investigate why the TFTP load is failing.
Hope this helps
Mahesh
255.255/help.cfg
(Timed out)\0x07
Press RETURN to get started!
*Mar  1 00:00:
00:03:12.823: %SYS-5-RESTART: System restarted --
Cisco IOS Sof
tware, C2600 Software (C2600-ADVENTERPRISEK9-M), Version 12.4(25c), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Thu 11-Feb-10 23:02 by prod_rel_team
*Mar  1 00:03:12.823: %SNMP-5-COLDSTART: SNMP agent on host help is undergoing a cold start
%Error opening tftp://255.255.255.255/cisconet.cfg (Timed out)
*Mar  1 00:03:42.819: %SYS-4-CONFIG_RESOLVE_FAILURE: System co
nfig parse from (tftp://255.255.255.255/cisconet.cfg) failed
*Mar  1 00:04:23.831: %SYS-4-CONFIG_RESOLVE_FAILURE: System co
nfig parse from (tftp://255.255.255.255/help-confg) failed
Before I could get started it tried to reboot on its own somehow, and then it started spitting out the config resolve errors. I think something is corrupt.
Reload IOS? Bad ram?
Hello Marc,
If youter is not allowing to do anything there the only way I can see is changing IOS. Make sure
do not go for latest IOS. Choose IOS which is 2-3 version back to latest one.
Mahesh
