tsubasa
Is this a "stackable switch" like the 3750 with a ring cable at the back so that I can manage every 2960 as one device?
Jerry Ye
The 2960 doesn't have the stackable port at the back. You have to use the uplink port to create your a stack. In term of management, you can use create a "Cluster" to manage the 2960 stack via a single IP address.
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_44_se/configuration/guide/swclus.html
HTH,
jerry
Joseph W. Doherty
No, but the newer 2975 support physical stacking like the 3750.
