11-13-2013 06:54 AM - edited 03-07-2019 04:35 PM
We have a older 3560 access switch that has high CPU usage the past three days. Solarwinds is telling us the switch is constantly around 90% - 95%. The switch has been around in our environment quite some time and this is the first we have seen this issue with it. So maybe it's just dieing a slow death. When I do a sho proc cpu s | e 0.00, I see the following:
Any ideas or thoughts on some of these processes?
Thanks.
11-13-2013 07:31 AM
It's well known that the Hulc process can use CPU, it's a cosmetic bug as I remember it.
However the amount of CPU used for CDP and STP is worrying to me. Do you think there could be a bridging loop? Are your interfaces using more bandwidth than usual? Do you see a spike in broadcasts on the interfaces?
Can you also post show proc cpu hist. If you have support I would open a TAC case.
Daniel Dib
CCIE #37149
11-13-2013 07:49 AM
From looking at my Solarwinds info, it does not appear the interfaces are using much for bandwidth or a spike in broadcasts. Here is a history of the CPU usage from Solarwinds as the problem has been going on for 3 days and the command on the cli only shows 60 mins from what I am seeing. I'd open a case with TAC but we no longer carry support on this device.
11-13-2013 11:07 AM
Everything appears to be back to normal for the CPU load on the switch. Didn't do anything on our end, seems to have resolved itself.
11-13-2013 01:36 PM
That's an old IOS you've got there. If you can, upgrade to 12.2(55)SE8.
