3560 poe switch stuck in loop
Hello
I recently reset a 3560 poe i have reset the switch but i keep getting:
nameofswitch-mdf1 con0 is now availble
press RETURN to get started.
Then I get
User Access  Verification.
Password:
'Course I don't know the password, which is i reset it.
-Thank you
-Shawn
Reza Sharifi
Here's what i have...followed your link!
Boot Sector Filesystem (bs) installed, fsid: 2
Base ethernet MAC Address: 00:1d:e6:42:60:80
Xmodem file system is available.
The password-recovery mechanism is enabled.
The system has been interrupted prior to initializing the
flash filesystem.  The following commands will initialize
the flash filesystem, and finish loading the operating
system software:
    flash_init
    boot
switch: flash_init
Initializing Flash...
flashfs[0]: 6 files, 1 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 12792832
flashfs[0]: Bytes available: 3206144
flashfs[0]: flashfs fsck took 10 seconds.
...done Initializing Flash.
switch: load_helper
Unknown cmd: load_helper
switch:
I tried several attempts. If I choose boot I get stuck in the loop. I do get the switch: prompt . But that's all. Never saves the flash_init. Get the same message everytime I boot.
"Version:1.0 StartHTML:000000280 EndHTML:000002315 StartFragment:000002029 EndFragment:000002283 StartSelection:000002032 EndSelection:000002279 SourceURL:https://supportforums.cisco.com/t5/forums/replypage/board-id/6016-discussions-lan-switching-routing/message-id/392524
system software:Version:1.0 StartHTML:000000280 EndHTML:000002315 StartFragment:000002029 EndFragment:000002283 StartSelection:000002032 EndSelection:000002279 SourceURL:https://supportforums.cisco.com/t5/forums/replypage/board-id/6016-discussions-lan-switching-routing/message-id/392524
system software:
flash_init
boot"
Jezz the one thing I could always do, if nothing else; is reset the switch!
Couple of things I tried
If I try enable I get
unknown cmd: enable.
Copy start run
start: no such device.
This switch may have been in a stack. Would that make difference?
Thank you
-Shawn "stuck in a loop"
So now I am thinking it's the IOS image.
system software:
    flash_init
    boot
switch: flash_init
switch: load_helper
switch:
system software:
flash_init
boot"
Copy start run
Thank you
Figuring its a image issue
I am trying to recover the Cisco IOS Image
switch: format flash:
switch: set BAUD 115200
close putty and reset baud rate
switch: copy xmodem: flash:c3560-ipservicesk9-mz.122-53.SE.bin
Now i getting:  xmodem: : I/O error
Tried a slower baud rate nada. Guess my next step is to setup a TFTP server
and try that.
LOL
Man did I brick this or what!
"If it doesn't work the first time try, try, and try again"
-anonymous aging IT tech
Hello Reza
Followed your link!
Here's what I have when I boot
system software:
flash_init
boot
So:
switch: flash_init
switch: load_helper
switch:
I tried several attempts. If I choose "boot" I get stuck in the loop. I do get the switch: prompt . But that's all. Never saves the flash_init. Get the same message every time I boot.
system software:
system software:
flash_init
boot"
Copy start run
Thank you
Thank you
