3560 policy doesn't work
MARCELO MATURO
I'm trying to applied a policy input in interface of 3560 to limite the traffic but it doesn't work. The config is simple:
class-map match-all prueba
match access-group 99
policy-map prueba
class prueba
police 10000000 8000 exceed-action drop
interface GigabitEthernet0/33
service-policy input prueba
Thank's
Marcelo
Peter010101
Hi Marcelo,
Did you enable mls qos (global command)?
What does your access-list 99 look like?
Also post your show policy-map interface GigabitEthernet0/33 output.
global mls is disabled.
99 is an standard ip access-list:
access-list 99 permit 76.253.168.52
sh policy-map interface gigabitEthernet 0/33
GigabitEthernet0/33
Service-policy input: prueba
Class-map: prueba (match-all)
0 packets, 0 bytes
offered rate 0 bps, drop rate 0 bps
Match: access-group 99
Class-map: class-default (match-any)
0 packets, 0 bytes
Match: any
0 packets, 0 bytes
rate 0 bps
You have to enable mls:
mls qos
