3560G and 2960 switch CPU loading
Wilson Kwok
Hi all,
I'm using PRTG monitoring switchs performance, the core switch 3560G CPU is 75% and outsite switch 2960 CPU is 25%, is it high loading of those switch ?
21 Replies 21
If you want to use 15.0 then settle for 15.0(2)SE4.
Do you mean just download the Lanbase ?
Look at the output to the command "sh version".  If your appliance says you are running LAN Base, then you download LAN Base.
If the output shows you to have "IP Services" then you download IP Services.
Leo Laohoo
Please don't forget to rate our useful posts.
Hi Leo,
Can you help me to download 3560G switch ipservices IOS, because I don't have the login ?
No I can't.  You will need to talk to your Cisco AM/SE for this.
Wilson Kwok
OK, thanks for your help, but I still thinking upgrade or not.
Sent from Cisco Technical Support Android App
