Usually, if you get it from CDW, they should work since it is well known company and has partnership with Cisco.
Using a none Cisco optic is a hit or miss. I have used Transition Networks optics with Cisco devices and they do usually work fine, but then again you never know until you try it.
http://www.transition.com/TransitionNetworks/
