3560X switch IOS upgarde issue
zahid perviz
I am facing issue while upgrading WS-C3560X-48PF-S switch. after upload once i restart its given following error message .
File "flash:/c3560e-ipbasek9-mz.150-2.SE4.bin" uncompressed and installed, entry point: 0x3000 executing... Boot process failed..
Please see show ver:
SW-HAB-3560X-48-NNOB-FF-04 uptime is 2 minutes System returned to ROM by power-on System restarted at 14:00:47 uae Wed Jan 29 2014 System image file is "flash:c3560e-ipbasek9-mz.122-55.SE3/c3560e-ipbasek9-mz.122-55.SE3.bin" This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption. Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately. A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html If you require further assistance please contact us by sending email to export@cisco.com. License Level: ipbase License Type: Permanent Next reload license Level: ipbase cisco WS-C3560X-48P (PowerPC405) processor (revision A0) with 262144K bytes of memory. Processor board ID FDO1416P05B Last reset from power-on 2 Virtual Ethernet interfaces 1 FastEthernet interface 52 Gigabit Ethernet interfaces 2 Ten Gigabit Ethernet interfaces The password-recovery mechanism is enabled. 512K bytes of flash-simulated non-volatile configuration memory. Base ethernet MAC Address : 44:D3:CA:8F:83:80 Motherboard assembly number : 73-12557-05 Motherboard serial number : FDO15280XE3 Model revision number : A0 Motherboard revision number : C0 Model number : WS-C3560X-48PF-S Daughterboard assembly number : 800-32786-01 Daughterboard serial number : FDO152904XN System serial number : FDO1416P05B Top Assembly Part Number : 800-31328-02 Top Assembly Revision Number : C0 Version ID : V02 CLEI Code Number : COMJP00ARB Hardware Board Revision Number : 0x03 Switch Ports Model SW Version SW Image ------ ----- ----- ---------- ---------- * 1 54 WS-C3560X-48P 12.2(55)SE3 C3560E-IPBASEK9-M
I trieed unversal as as ip base . It failed in both case . any one came help.
Haihua Rong
Hello Zahid,
That switch is it in standalone or was part of a stack stack? Can you try c3560e-ipbasek9-mz.150-2.SE5.bin?
Haihua
Yes its stand alone switch.
Today i tested followeing things.
1. first i upgarde 12.55.SE8
2.12.58.SE3
3.15.01 SE4
it was sucessful . Once i tried 15.0.2 SE4 its not booting . Could you help me fast.
we face problem for IOS upgrade on 3560X-48PF-S switch,
TARGET IMAGE:  c3560e-ipbasek9-mz.150-2.SE4.bin
we successfully upgrade till c3560e-ipbasek9-mz.150-1.SE3.bin . after we stuck with upgrade.
To isolate space issue, we boot from Usbflash which is having more than 1GB space. still its not working.
SWitch supported for c3560e-ipbasek9-mz.150-2.SE4.bin as per cisco
