3750-x Same CRC and Input Error
Tauer Drumond
Hi all,
Recently, I'd connected a 2960 together with a 3750-X
2960 - Port G0/1 (WS-C2960-24TT-L - SW: Version 15.0(2)SE2)
3750-X Port G1/0/9 (WS-C3750X-48 - SW: Version 15.0(2)SE2)
CRC and Input Error increase equally, only on 3750-X:
21895 input errors, 21895 CRC, 0 frame, 0 overrun, 0 ignored
They are the same.
I've tried everything to figure out what's happening. Change the cable, change duplex e speed, etc. And nothing happens
Please,
anyone has an idea to help me out?
Thank you all
12 Replies 12
acampbell
Can you post
sh run int g1/0/9 - from the 3750
sh run int g0/1 from the 2960
also sh int g1/0/9
and sh int g0/1
Alex
Regards, Alex. Please rate useful posts.
Hey Campbell, thanks for reply.
Follow the output below:
Switch 3750-X
interface GigabitEthernet1/0/9
 switchport mode trunk
 switchport nonegotiate
 load-interval 30
 duplex full
 udld port aggressive
 ip dhcp snooping trust
GigabitEthernet1/0/9 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is a493.4c05.ef09 (bia a493.4c05.ef09)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:04, output 00:00:00, output hang never
  Last clearing of "show interface" counters 22:36:46
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 29000 bits/sec, 17 packets/sec
  30 second output rate 65000 bits/sec, 61 packets/sec
     2676932 packets input, 881408261 bytes, 0 no buffer
     Received 40328 broadcasts (21174 multicasts)
     38910 input errors, 38910 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 21174 multicast, 0 pause input
     6945710 packets output, 3289042111 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Switch 2960
interface GigabitEthernet0/1
 load-interval 30
GigabitEthernet0/1 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 9c4e.2050.a119 (bia 9c4e.2050.a119)
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 22:48:59
  30 second input rate 49000 bits/sec, 50 packets/sec
  30 second output rate 14000 bits/sec, 9 packets/sec
     6995428 packets input, 3295389496 bytes, 0 no buffer
     Received 3792687 broadcasts (3519113 multicasts)
     0 watchdog, 3519113 multicast, 0 pause input
     2721515 packets output, 882553595 bytes, 0 underruns
1.  This is a copper link so I'd recommend you disable UDLD port aggressive.
2.  Enable auto duplex and auto speed.  The CRC and Input Errors are caused by the "duplex full" setting.
Totally agree with Leo.
Both ends of the link should be configured exactly the same as far as the physical settings are concerned.
In your set up you have full duplex ath e 3750 and auto duplex on the 2960.
For the UDLD have a read at this link:-
http://www.cisco.com/c/en/us/support/docs/lan-switching/spanning-tree-protocol/10591-77.html
Alex
Hi Leo and Campbell,
I've tried this alrady, and nothing happens. CRC and input error increase at same time with same values
Here's the output of actuall configurations:
3750-X
     reliability 253/255, txload 1/255, rxload 1/255
  Last input 00:00:01, output 00:00:00, output hang never
  Last clearing of "show interface" counters 00:00:43
  30 second input rate 171000 bits/sec, 140 packets/sec
  30 second output rate 2428000 bits/sec, 280 packets/sec
     6216 packets input, 812642 bytes, 0 no buffer
     Received 34 broadcasts (29 multicasts)
     84 input errors, 84 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 29 multicast, 0 pause input
     12241 packets output, 13900470 bytes, 0 underruns
 load-interval 30
end
2960
  Last input 00:00:00, output 00:00:03, output hang never
  Last clearing of "show interface" counters 00:04:18
  30 second input rate 2178000 bits/sec, 254 packets/sec
  30 second output rate 158000 bits/sec, 130 packets/sec
     60331 packets input, 56292783 bytes, 0 no buffer
     Received 14890 broadcasts (12708 multicasts)
     0 watchdog, 12708 multicast, 0 pause input
     30715 packets output, 6022703 bytes, 0 underruns
 load-interval 30
3750-X
Gotcha!
You've got a cable problem.
You've got a 3750X and this is good.  Run a TDR to determine WHERE the problem is.
Hey Leo...
I ran a TDR test, but it seems to be all ok.. :(
show cable-diagnostics tdr interface gigabitEthernet 1/0/9
TDR test last run on: May 07 21:34:17
Interface Speed Local pair      Pair length    Remote pair Pair status
Gi1/0/9   1000M Pair A     0    +/- 10 meters Pair A            Normal
                            Pair B     0    +/- 10 meters Pair B            Normal
                            Pair C     0    +/- 10 meters Pair C            Normal
                            Pair D     0    +/- 10 meters Pair D            Normal
And... issuing the commando on 2960, I got this:
TDR test last run on: May 07 21:42:34
Gi0/1     1000M Pair A     8    +/- 10 meters Pair B      Normal
                          Pair B     8    +/- 10 meters Pair A      Normal
                          Pair C     8    +/- 10 meters Pair D      Normal
                          Pair D     8    +/- 10 meters Pair C      Normal
Ok.  I trust TDR but I trust your "sh interface" output more.
What you've seen is not abnormal.  This is true, for example, if the entire cable run has some vibrations which can cause the cable to move.  That's why when you first put the "sh interface" output there was nothing suspicious.  Same with your TDR.  But when you published the second "sh interface" the fault materialize.
I'd start changing the cables at both ends.  But I would start at the 3750-end.  The 3750X TDR result doesn't smell "right".
Hi Leo,
the swtiches are connected directly. No horizontal cables or patch pannel.
I've changed this cable already to a Cat6 one, but no luck.
I have eight 2960S-48FPS-L connected in this 3750-X in the same fashion, through a GLC-T and I have no problem at all. All counters are clear.
The only problem is with this different 2960-24TT-L.
I'm guessing the problem is with the 2960-24TT-L :(
As a test can you drop the connection to 100M Full duplex at both ends
Clear counters and repost outputs
Alex
I've changed the speed and duplex to 100 Full on both sides, but the interface in 2960 never goes UP being in duplex full (I dont know why) It only works in duplex auto.
If this interface is in "duplex auto" and 3750-x is in duplex full, the duplex on 2960 negotiates in half.
So.. I can only work in 100 Full not forced... but, CRC and input error increase at same fashion
I'll try to chaged the cable again and repeat all tests
Really????  I find that hard to believe.  Look at the wire maps.  They are totally different.
I've never seen one like this before.  Must be MDI/MDI-X kicking in.
Forgive me but I ain't belittling you.  Can I ask you to change the cable TWO MORE TIMES?
There's a reason why I always carry three items of the same part.
