3850 with high cpu
radams123
I have a network without around 40 switches (3560, 2960, 3750x)   with a 4510 as my core.  Plan is to replace all of the 3560 and 2960 with 3850x.   I noticed after I installed a few of the 3850's that I started having some minor, unexplainable network issues.    This week, I installed another 3850 in a closet and tied it back to the core via 1GB fiber.   About twice a day, the users would call stating the network was down.   After investigation, I found that the 3850 was running very high cpu and a reboot would fix it for about 6 hours and it would start again.  I replaced the 3850 in question with another 3850 and the same problem came back this morning.   I decided to start looking at the other 3850's cpu history aand it appears that they are  spiking CPU at the same times.    The software version is 03.02.03.   Anyone got any ideas.   Should I try upgrading the software as they are not mixing well in my network.
Arjun Sarkar
Hello ,
 Please check what is the top talkers at the time  og high CPU on 3850.  Please execute follwing commands to check the status,
- show process cpu sorted | ex 0.00
- show platform punt client - This is to check if there is any queue is stuck.
PLeasse do refer the troubleshooting guide which is available on CCO.
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-3850-series-switches/117594-technote-hicpu3850-00.html
Best Regards
Arjun
Please rate if it helps.
it could be a bug theres a few for this fed process it runs high on certain ios-xe
https://tools.cisco.com/quickview/bug/CSCuo14511
Heres how you can check certain issues with fed process for 38s
Mark Malone
yes the proc cpu sorted willl tell what happening live as Arjun has stated really need that , if you do suspect buggy software move to 3.6.3 thats the safe harbour version least amount of caveats fo that platform
if your not around to capture it apply this it will do it for you and send the results to flash, just chnage it to your local file system below then you can export it
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/116141-trouble-eem-scripts-00.html
event manager scheduler script thread class default number 1
event manager applet High_CPU
event snmp oid 1.3.6.1.4.1.9.9.109.1.1.1.1.3.1 get-type exact entry-op ge
entry-val 50 poll-interval 0.5
action 0.0 syslog msg "High CPU DETECTED. Please wait - logging Information
to file system:high_cpu.txt"
action 0.1 cli command "enable"
  action 0.2 cli command "show clock | append file system:high_cpu.txt"
  action 1.2 cli command "term length 0"
  action 1.3 cli command "show process cpu sorted | append file system:high_cpu.txt"
  action 1.4 cli command "show log | append file system:high_cpu.txt"
  action 1.5 cli command "show interfaces | append file system:high_cpu.txt"
  action 1.6 cli command "term length 24"
 It looks like the fed and iosd process is running high.   As stated earlier, I plan to upgrade the software to 3.6.3 to see if it helps but any suggestions would be helpful.
PT-3850#show proc cpu sorted
Core 0: CPU utilization for five seconds: 66%; one minute: 74%;  five minutes: 63%
Core 1: CPU utilization for five seconds: 68%; one minute: 68%;  five minutes: 56%
Core 2: CPU utilization for five seconds: 74%; one minute: 71%;  five minutes: 57%
Core 3: CPU utilization for five seconds: 74%; one minute: 71%;  five minutes: 57%
PID    Runtime(ms) Invoked  uSecs  5Sec     1Min     5Min     TTY   Process
5716   2820903     27848925 179    41.04    41.02    32.83    1088  fed
9400   2379157     10020564 362    23.70    23.90    19.64    0     iosd
5718   2595175     74753447 1011   3.43     3.48     3.51     0     stack-mgr
6396   3134705     75308221 78     1.97     2.01     1.74     0     pdsd
5717   3869422     34627272 23     0.28     0.15     0.14     0     platform_mgr
6407   357565      7652782  1169   0.14     0.14     0.14     0     cpumemd
9396   2358425     36879904 29     0.09     0.12     0.12     0     wcm
6387   104800      148013   708    0.05     0.01     0.05     0     oom_poll.sh
1      1650        1051     1569   0.00     0.00     0.00     0     init
2      0           125      0      0.00     0.00     0.00     0     kthreadd
3      11840       1012588  11     0.00     0.00     0.00     0     migration/0
4      0           3        0      0.00     0.00     0.00     0     sirq-high/0
5      85792       15095491 29     0.00     0.00     0.00     0     sirq-timer/0
6      0           8        0      0.00     0.00     0.00     0     sirq-net-tx/0
7      20          839      23     0.00     0.00     0.00     0     sirq-net-rx/0
8      720         85614    8      0.00     0.00     0.00     0     sirq-block/0
9      0           8        0      0.00     0.00     0.00     0     sirq-block-iopo
10     0           1152     0      0.00     0.00     0.00     0     sirq-tasklet/0
11     1381980     58561207 23     0.00     0.00     0.00     0     sirq-sched/0
12     2860        59135    48     0.00     0.00     0.00     0     sirq-hrtimer/0
13     2326115     13158949 82     0.00     0.00     0.00     0     sirq-rcu/0
14     12650       1979489  6      0.00     0.00     0.00     0     desched/0
15     42950       3768793  11     0.00     0.00     0.00     0     migration/1
16     0           15       0      0.00     0.00     0.00     0     sirq-high/1
17     284440      14394066 1      0.00     0.02     0.02     0     sirq-timer/1
18     0           19       0      0.00     0.00     0.00     0     sirq-net-tx/1
19     0           6297     0      0.00     0.00     0.00     0     sirq-net-rx/1
20     420         28829    14     0.00     0.00     0.00     0     sirq-block/1
21     0           20       0      0.00     0.00     0.00     0     sirq-block-iopo
22     0           21       0      0.00     0.00     0.00     0     sirq-tasklet/1
23     161430      74587634 2      0.00     0.00     0.00     0     sirq-sched/1
24     0           53383    0      0.00     0.00     0.00     0     sirq-hrtimer/1
25     368810      11908040 3      0.00     0.00     0.00     0     sirq-rcu/1
26     10470       1445360  7      0.00     0.00     0.00     0     desched/1
27     70960       4718895  15     0.00     0.00     0.01     0     migration/2
28     0           27       0      0.00     0.00     0.00     0     sirq-high/2
29     21990       11499905 0      0.00     0.00     0.03     0     sirq-timer/2
30     0           33       0      0.00     0.00     0.00     0     sirq-net-tx/2
31     20          8559     2      0.00     0.00     0.00     0     sirq-net-rx/2
32     120         7306     16     0.00     0.00     0.00     0     sirq-block/2
33     0           32       0      0.00     0.00     0.00     0     sirq-block-iopo
34     0           33       0      0.00     0.00     0.00     0     sirq-tasklet/2
35     11450       69001545 0      0.00     0.00     0.00     0     sirq-sched/2
36     0           43691    0      0.00     0.00     0.00     0     sirq-hrtimer/2
37     33540       10685313 0      0.00     0.00     0.00     0     sirq-rcu/2
38     19090       3277703  5      0.00     0.00     0.00     0     desched/2
39     44670       2636657  16     0.00     0.00     0.00     0     migration/3
40     0           39       0      0.00     0.00     0.00     0     sirq-high/3
41     0           10755851 0      0.00     0.03     0.04     0     sirq-timer/3
42     0           42       0      0.00     0.00     0.00     0     sirq-net-tx/3
43     20          9673     2      0.00     0.00     0.00     0     sirq-net-rx/3
44     30          3411     8      0.00     0.00     0.00     0     sirq-block/3
45     0           44       0      0.00     0.00     0.00     0     sirq-block-iopo
46     0           45       0      0.00     0.00     0.00     0     sirq-tasklet/3
