50% packet loss on GRE tunnel
Europacom.net
Good Morning
We have a site were we have a 887 cisco hsiung a GRE tunnel
When pinging anything froom the tunnel source to the tunnel dest on the local lan we get a  50% packet loss
ping
Protocol [ip]:
Target IP address: 10.9.93.22
Repeat count [5]: 100
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]:
Sweep range of sizes [n]:
Sending 100, 100-byte ICMP Echos to 10.9.93.22, timeout is 2 seconds:
Success rate is 50 percent (50/100), round-trip min/avg/max = 48/51/96 ms
debug ip icmp detail output
001640: *Sep 20 04:55:01.158 PCTime: FIBipv4-packet-proc: route packet from Vlan1 src 10.9.93.22 dst 172.22.0.1
001641: *Sep 20 04:55:01.158 PCTime: FIBfwd-proc: Default:172.22.0.0/16 proces level forwarding
001642: *Sep 20 04:55:01.158 PCTime: FIBfwd-proc: depth 0 first_idx 0 paths 1 long 0(0)
001643: *Sep 20 04:55:01.158 PCTime: FIBfwd-proc: try path 0 (of 1) v4-ap-Tunnel1 first short ext 0(-1)
001644: *Sep 20 04:55:01.158 PCTime: FIBfwd-proc: v4-ap-Tunnel1 valid
001645: *Sep 20 04:55:01.158 PCTime: FIBfwd-proc: Tunnel1 no nh type 3  - deag
001646: *Sep 20 04:55:01.162 PCTime: FIBfwd-proc: ip_pak_table 0 ip_nh_table 65535 if Tunnel1 nh none deag 1 via fib 0 path type attached prefix
001647: *Sep 20 04:55:01.162 PCTime: FIBfwd-proc: Default:172.22.0.0/16 not enough info to forward via fib (Tunnel1 none)
001648: *Sep 20 04:55:01.162 PCTime: FIBipv4-packet-proc: packet routing failed
001649: *Sep 20 04:55:01.162 PCTime: IP: tableid=0, s=10.9.93.22 (Vlan1), d=172.22.0.1 (Tunnel1), routed via RIB
001650: *Sep 20 04:55:01.162 PCTime: IP: s=10.9.93.22 (Vlan1), d=172.22.0.1 (Tunnel1), len 100, output feature
001651: *Sep 20 04:55:01.162 PCTime:     ICMP type=0, code=0, TCP Adjust MSS(40), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
001652: *Sep 20 04:55:01.162 PCTime: IP: s=10.9.93.22 (Vlan1), d=172.22.0.1 (Tunnel1), len 100, output feature
001653: *Sep 20 04:55:01.162 PCTime:     ICMP type=0, code=0, Post-Ingress-NetFlow(52), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
001654: *Sep 20 04:55:01.162 PCTime: IP: s=10.9.93.22 (Vlan1), d=172.22.0.1 (Tunnel1), len 100, sending full packet
001655: *Sep 20 04:55:01.162 PCTime:     ICMP type=0, code=0
this one has us puzzled.. any ideas would be really helpful.
replicated the setup exatly in our lab  and it works 100% with exactly the same config.
Andre
cadet alain
could you post your config.
Alain
Andre
Some things in your post have me puzzled. You show the ping command with this
but in the debug output Target IP address: 10.9.93.22 appears as the source and the destination is 172.22.0.1.
Can you provide clarification about the relationship of the command that you show and the debug?
Another thing that I notice is that the debug seems to show attempts to forward two packets to the same destination
So why does one fail and the other succeed with the same destination address. It seems that something in going on with the routing logic.
This makes me quite agree with Alain that it would be helpful if you would post the configuration. I wold also like to see the output of show ip route - or if the routing table is too large then the output of show ip route 10.9.93.22 and of show ip route 172.22.0.1.
Rick
Rick
