6500 in VSS QoS problem
Difan Zhao
Level 5
Level 5
Hi experts,
I have two 6500 in VSS. I have WAN connection connected on port on Sup card on each chassis and they are in a port-channel. Sup is VS-SUP2T-10G and it is in slot 5. The ports are Gi1/5/3 and Gi2/5/3. IOS is 15.0(1)SY1
I am trying to apply queueing configuration on the interface but failed. I got this error message
(config-if)# wrr-queue bandwidth 1 80 20
HWIF-QOS: QoS configs are not allowed on VSL Portgroup
I googled and some threads say that in VSS I can't configure queueing on sup card ports. They are always disabled. Is it true? Is it only limitation on sup ports or is it on other ports as well?
Thanks!
Difan
15 Replies 15
r.pfffli
Does the limitation regarding QoS on the Supervisor if one port is vss and the other is an uplink, also apply to the Cat4500 with Sup7-E? I cannot find any documentation about that....
regards
Roger
