6500 Modules
a1okojie
Does the Catalyst 6500 support line cards or modules with 10G fiber ports, I do not meant the ports on the SUP720?
Thanks.
ankbhasi
Hi Friend,
Hope this should help you.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_data_sheet09186a00801dce34.html
Ankur
*Pls rate all helpfull post
plumbis000
The only 10GE card for the 6k is the 6704-10GE card. All 67xx cards are only supported on the Sup720, so the short answer is no.
The WS-X6708-10GE-3C module is also available. It's 8-port 10GE with X2 ports instead of XENPAK and has a few other features.
