6500 QoS not enabling rcv-queue defaults
Robert Juric
One one of our Cisco 6509s I've globally enabled QoS and set a port to "trust cos". However when I look at the queueing for that interface, I notice that the receive queue thresholds have not changed to the default.
I'm kind of new to QoS so I'm not sure if I'm missing something.
We are using a Cisco 6509 running 12.2(33)SXI3 using the WS-X6724-SFP card. I thought I'd be seeing the default tail-drop thresholds, but instead I still see the defaults as if QoS were not enabled:
Queueing Mode In Rx direction: mode-cos
    Receive queues [type = 1q8t]:
    Queue Id    Scheduling  Num of thresholds
       01         WRR                 08
    WRR bandwidth ratios:  100[queue 1]
    queue-limit ratios:    100[queue 1]
    queue tail-drop-thresholds
    1     100[1] 100[2] 100[3] 100[4] 100[5] 100[6] 100[7] 100[8]
    queue thresh cos-map
    1     1      0 1 2 3 4 5 6 7
    1     2
    1     3
    1     4
    1     5
    1     6
    1     7
    1     8
acampbell
Robert,
QOS - A huge subject
Yes you enable qos mls globally
and you can "trust cos" on interfaces
BUT
You need to carry out some more config
Your 6724 uses a 1P3Q8T queing mechanism
Please see this link
http://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/QoS_SRND_40/QoSCampus_40.html#wp1120476
Hope this helps
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
I get a 403 Forbidden File or Application error when I follow the link.
Yes the 6724 has a 1P3Q8T *transmit* queue, but doesn't it also have a 1Q8T receive queue with tail-drop thresholds?
I know I don't have all the pieces implement yet, but I was just looking at the rx queue at this point.
Unless I'm misunderstanding something, after enabling QoS globally, the standard COS to Threshold mappings should be enabled on the interface, at least the interfaces that are setup to trust COS or DSCP?
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/qos.html#wp1478881
Robert
I think I may have found an issue...
I had configured trust dscp and trust cos on different interfaces on the same ASIC. When I went back and removed the trust dscp from interfaces on that ASIC, my default rcv-queue thresholds were there.
Robert,
Sorry you can see the link.
I have tried to attach the pdf in this reply.
I thinkj you will be interested in this information.
Alex.
