11-16-2016 02:54 AM - edited 03-08-2019 08:11 AM
Hi All,
I need to order the 10Gb transceivers for Sup2t .
Do you know the model number or what cable connection they take ?
I guess it can span 1-2 miles if using single mode fibre?
Also if you have qud sup sup2t, I believe the standby supervisors and warm-rpr modules will have their uplink forwarding so can be used to form a port channel, right ?
thanks
Solved! Go to Solution.
11-16-2016 07:27 AM
See sup6t section in: http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/10GE_Tx_Matrix.html#_Toc458157399
Believe SM can span up to 70Km with "right" optics.
Yes, I believe you can form a port-channel using standby sup ports.
11-16-2016 07:27 AM
11-17-2016 04:02 AM
many thanks,
I have confirmed that the standby ports will forward
thanks again
