802.1x with MAB
Can the Microsoft IAS Server be used as RADIUS Server for 802.1x with MAC Authentication Bypass instead Cisco ACS?
wong34539
Level 6
Level 6
The VLAN feature only supports MAC filtering, 802.1X, and Wi-Fi Protected Access (WPA). The VLAN feature does not support web authentication or IPSec. The operating system's local MAC Filter database has been extended to include the interface name. This allows local MAC filters to specify which interface the client should be assigned. A separate RADIUS server can also be used, but the RADIUS server must be defined using the Security menus.
For further information click this link.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008082d5b5.shtml#conf
bassie
Yes, use the mac-address for username AND password in IAS.
