8540 CSR help
mfoyster11
I have a 8540 CSR that i need to load IOS from tftp but my rom does not have TFTPDNL command what are the variables to set and how do you set the enet interface
Lucien Avramov
Level 10
Level 10
On 8540, the command DNLD should work, try that one instead of TFTPDNLD.
Else, format a PCMCIA card in another 8540, copy the image and insert in that 8540.
Hello I don't have another 8540 running i lost my Pcmcia flash cards in a fire along with 2 other 8540, these 8540 that i have were my spares i have an ios and config but tftp isnt working right on that rom , also which ethernet port do you use for tftp it does not seem to be enet on route processor
