9300 Auto QoS
uppermost
What is the difference between if I configure port with
auto qos voip cisco-phone
and
auto qos trust cos
I am trying to replicate interface configuration from old (3850) to the new switch (9300)
interface GigabitEthernet1/0/45
switchport access vlan 414
switchport mode access
switchport voice vlan 514
switchport port-security maximum 2
switchport port-security violation restrict
switchport port-security aging time 2
switchport port-security aging type inactivity
srr-queue bandwidth share 1 30 35 5
priority-queue out
mls qos trust device cisco-phone
mls qos trust cos
macro description cisco-phone
spanning-tree portfast edge
spanning-tree bpduguard enable
service-policy input AUTOQOS-SRND4-CISCOPHONE-POLICY
On the new 9300 I can configure either auto qos trust cos or auto qos voip cisco-phone but not both as it is on the old switch.
 They overlap most configuration. Only the highlighted will be additional if you use cisco-phone. I would recommend use cisco-phone if that is the case for this port.
The following is an example of the auto qos voip cisco-phone command and the applied policies and class maps.
The following policy maps are created and applied when running this command:
  • AutoQos-4.0-CiscoPhone-Input-Policy
  • AutoQos-4.0-Output-Policy
The following class maps are created and applied when running this command:
  • AutoQos-4.0-Voip-Data-Class (match-any)
  • AutoQos-4.0-Voip-Signal-Class (match-any)
  • AutoQos-4.0-Default-Class (match-any)
  • class-default (match-any)
  • AutoQos-4.0-Output-Priority-Queue (match-any)
  • AutoQos-4.0-Output-Control-Mgmt-Queue (match-any)
  • AutoQos-4.0-Output-Multimedia-Conf-Queue (match-any)
  • AutoQos-4.0-Output-Trans-Data-Queue (match-any)
  • AutoQos-4.0-Output-Bulk-Data-Queue (match-any)
  • AutoQos-4.0-Output-Scavenger-Queue (match-any)
  • AutoQos-4.0-Output-Multimedia-Strm-Queue (match-any)
auto qos trust cos
The following is an example of the auto qos trust cos command and the applied policies and class maps.
  • AutoQos-4.0-Trust-Cos-Input-Policy
auto qos trust cos
