Access-list will not engage properly in 3750
hobbe
Level 7
Level 7
I have a 3750 with Ios version 12.2.35.se5 where the access-list will not engage properly.
I found something on the bugfix for the ios version but the access-list is only 41 rows. so it should not apply. and there is nothing on the type of hardware.
here is the access-list
IA = Ip Adress
NA = Network Address
WCM = Wildcard mask
Port = a tcp/udp port or range
Extended IP access list 120
10 permit tcp host IA gt PORT host IA eq PORT
20 permit tcp host IA gt PORT host IA eq PORT
30 permit tcp host IA gt PORT host IA eq PORT
40 permit tcp host IA gt PORT host IA eq PORT
50 permit tcp host IA gt PORT host IA eq PORT
60 permit tcp host IA gt PORT host IA eq PORT
70 permit tcp host IA gt PORT host IA eq PORT
80 permit tcp host IA gt PORT host IA eq PORT
90 permit tcp host IA gt PORT host IA eq PORT
100 permit tcp host IA gt PORT host IA eq PORT
110 permit tcp host IA gt PORT host IA eq PORT
120 permit tcp host IA gt PORT host IA eq PORT
130 permit tcp host IA gt PORT host IA eq PORT
140 permit tcp host IA gt PORT host IA eq PORT
150 permit tcp host IA gt PORT host IA eq PORT
160 permit tcp host IA gt PORT host IA eq PORT
170 permit tcp host IA gt PORT host IA eq PORT
180 permit tcp host IA gt PORT host IA eq PORT
190 permit tcp host IA host IA eq PORT
200 permit tcp host IA host IA eq PORT
210 permit ip host IA NA WCM
220 permit ip host IA NA WCM
230 permit tcp NA WCM NA WCM eq PORT
240 permit tcp NA WCM NA WCM eq PORT
250 permit tcp NA WCM NA WCM eq PORT
260 permit tcp NA WCM NA WCM eq PORT
270 permit tcp NA WCM NA WCM eq PORT
280 permit tcp NA WCM NA WCM eq PORT
290 permit tcp NA WCM NA WCM eq PORT
300 permit tcp NA WCM NA WCM eq PORT
310 permit tcp NA WCM NA WCM eq PORT
320 permit tcp NA WCM NA WCM eq PORT
330 permit tcp NA WCM NA WCM eq PORT
340 permit tcp NA WCM eq PORT NA WCM gt PORT
350 permit tcp NA WCM eq PORT NA WCM gt PORT
360 permit tcp NA WCM eq PORT NA WCM gt PORT
370 permit tcp NA WCM eq PORT NA WCM gt PORT
380 permit tcp NA WCM eq PORT NA WCM gt PORT
390 deny ip IP NA WCM any
Is it me ?
am I missing something or is it a bug in the system ?
There is no errormessage when i enter the access-list to the switch.
it just dont take.
cisco_lad2004
Level 5
Level 5
are you using Enhanced Image ?
Please post Sh ver.
Sam
TORBJORN
You have hidden so much detail that it is hard to know what the problem is. But I do have some observations and some suggestions:
- I am not clear in your description whether the problem is that the access list is not working at all, or whether things that work without the access list do not work when you apply the access list. Perhaps you can clarify what the problem really is?
- you show us the access list but provide no information about how the access list is applied. Can you give us specifics about how the access list is applied? Until the access list is applied it will have no effect.
- I notice that almost all the permit statements are to permit various TCP traffic. There are only 2 statements that permit ip and they permit traffic from specific host(s) to certain limited destinations. This will not allow things like ping to work - at least for most of your network. And it is likely that it will not permit DNS to work - at least for most of your network. So perhaps the problem is overly restrictive logic in the access list.
Rick
Rick
Hi rburts
The access-list is applied on a interface with the command "ip access-group 120 in"
in an Layer three routed interface with an IP. This applies the access-list on inbound traffic to that interface.
If we take away the access-list with the command "no access-list 120" the communication works.
when we add it only some hosts can use it even though the lines are the same fx
IP A wants to reach IP Z - it works
same line exactly (except for the IP B ip) for IP B to reach the IP Z does not work.
Example.
permit tcp host 192.168.1.1 gt 1234 host 192.168.2.1 eq 1234 "works"
permit tcp host 192.158.1.2 gt 1234 host 192.168.2.1 eq 1234 "does not work"
ICMP is not required nor desired, neither is DNS for other than the two hosts with ip permitted.
IP addresses used in examples are fictive.
Hope this clarifies things.
No its the preloaded IP-BASE
Cisco IOS Software, C3750 Software (C3750-IPBASE-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1)
