ACL on Cisco Switch to isolate machines
cecodoorit
I am trying to isolate a host on our network to only see the server, and isolate it from everything else on the network.   PCA is 10.10.10.2  Server is 10.10.10.5  I need the server to communicate with PCA and all other devices, but need PCA to only communicate with the Server.   I am using a 3750x switch, both are on the same vlan.  I tried using an acl on the interface that pca is connected to :
access-list 5 permit 10.10.10.5 0.0.0.0
interface gi2/0/11 (interface where pca connects)
ip access-group 5 in
with a contstan ping going, when I apply the access group, i lose connection to pca from everything including the server in the permit statement.
Is there a better approach?  thanks in advance
Seb Rupik
Hi there,
As you had it, your ACL was only permitting traffic sourced from 10.10.10.5 (the server), it would not of had the desired effect.
Replace it with:
ip access-list ext PCA_LIMIT
  permit ip host 10.10.10.2 host 10.10.10.5
int gi2/0/11
ip access-group PCA_LIMIT in
cheers,
Seb.
6 Replies 6
Seb Rupik
Hi there,
Replace it with:
int gi2/0/11
cheers,
Seb.
ok I tested the below, and that seems to work, however if I add another permit statement then I lose the ping from the original server AND the secondary permit device.
access-list  110 permit IP host (ip of device) host (ip of server)
pings from the server fine, and drops pings from other devices (this is what I want)
adding the below
access-list 110 permit IP host (ip of device) host (ip of 2nd server)
causes the ping to fail on the first server and all devices, as well as unable to ping from 2nd server
Strange. Please provide the output from sh access-list
cheers,
Seb.
Sorry, I was using the wrong access-list identifier on the second statement
It is working, thank you for the assist
Julio E. Moisa
If they are over the same vlan, you could use switchport protected. Please check this link:
https://learningnetwork.cisco.com/thread/31691
There are other ways like private vlan, but it could be more complex.
Now your ACL at simple sight will block the rest of the traffic, you need to specify that it will allow everything else:
access-list 5 deny host 10.10.10.5
access-list 5 permit any
interface gi2/0/11
In order to see if it is working, you can execute: show access-list 5 (you will see hits)
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Julio,
I am not looking to block the .5 and allow everything else, but just the opposite, allow communication between the .2 and .5 and nothing else.
Seb,
I am waiting on the device to come online so I can test your suggestion.  It is at a remote location.  I will update after I test.
Thank you to both of you for your suggestions
