ACLs not working after restart
rrangelov
Dear all,
I have a problem with router CISCO 881. I have configured rate-limiting on ACLs. There are two strange things for me on this configuration.
1. If I create the ACLs and then the rate-limiting rule, the limiting is not working at all. If I configure them vice-versa it is just fine.
2. After entering "copy run start" command and then restart of the router, the rate limiting is also not working. If I recreate the ACLs, it works fine again.
Do you have any idea what is happening?
Thanks in advance!
Best regards
0 Replies 0
