Adding 3rd switch to stack without breaking stack
mahesh18
Level 6
Level 6
Hi Everyone,
I need to add 3rd switch to stack.Currently it has 2 switches in stack and it is running some critical applications so i can not afford downtime.
Current cable setup is
3750#sh switch
Switch/Stack Mac Address : 001b.90e7.d480
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
*1       Master 001b.90e7.d480     10     0       Ready
 2       Member 001b.90e7.0580     8      0       Ready
3750#sh switch stack-ports
  Switch #    Port 1       Port 2
    1           Ok           Ok
    2           Ok           Ok
3750#sh switch neighbors
      1         2             2
      2         1             1
Need to know how can i bring 3rd cable to stack without downtime.
MAhesh
Reza Sharifi
Hi Mahesh,
Here is the instruction on how to add a switch to a stack as a member/slave.
Make sure to turn off the switch before connecting the stack cable.
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-3750-series-switches/71925-cat3750-create-switch-stks.html#stack3
Also, I would still have an outage window when doing this just in case something goes wrong.  It is always good to be safe than sorry.
Good Luck
Reza
Reza Sharifi
Hi Mahesh,
Good Luck
Reza
Many thanks Reza.
MAhesh
Glad to help Mahesh!!
How have you been?
Has been a long time.
Reza
I am fine.
Mostly working on firewalls,IPS devices these days.
But routing and switching comes also under my job responsibility
MAhesh
