Adding a 2960x switch to an existing switch
ashfaqmd
I want to add a new cisco switch WS-C2960X-24PS-L to a existing stack cisco stack switches ws-2960s-48FPD-L. Cisco switches details mention below
Existing Stack Switches model
Switch Ports Model              SW Version            SW Image
*    1 52    WS-C2960S-48FPD-L  15.0(2)EX5            C2960S-UNIVERSALK9-M
     2 52    WS-C2960S-48FPS-L  15.0(2)EX5            C2960S-UNIVERSALK9-M
     3 52    WS-C2960S-48FPS-L  15.0(2)EX5            C2960S-UNIVERSALK9-M
adding a new cisco switch 2960X
* 1 28 WS-C2960X-24PS-L 15.0(2a)EX5 C2960X-UNIVERSALK9-M
Please help me to add a new cisco 2960x switch.
5 Replies 5
Leo Laohoo
That should be fine.  The 2960X should be able to join the stack.
So what you need to do first is to ensure the 2960X is POWERED OFF before connecting the stacking cable.  (Failure to do so will cause the entire stack to reboot.)
I switch off the new cisco switch 2960x before connecting the stack cable, but still unable to add existing stack switches.
BR
Connect a console cable to the 2960X and reboot.
Post the entire boot-up process and the stack joining process.
CPU rev: B
Image passed digital signature verification
Board rev: 18
Testing DataBus...
Testing AddressBus...
Testing Memory from 0x00000000 to 0x1fffffff... - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | / - \ | /
Using driver version 4 for media type 1
Xmodem file system is available.
Base ethernet MAC Address: b0:7d:47:4a:9c:00
The password-recovery mechanism is enabled.
USB EHCI 1.00
USB EHCI 1.00
USB Console INIT
Initializing Flash...
mifs[5]: 12 files, 1 directories
mifs[5]: Total bytes : 1806336
mifs[5]: Bytes used : 834560
mifs[5]: Bytes available : 971776
mifs[5]: mifs fsck took 0 seconds.
mifs[6]: 1 files, 1 directories
mifs[6]: Total bytes : 3870720
mifs[6]: Bytes used : 971264
mifs[6]: Bytes available : 2899456
mifs[6]: mifs fsck took 1 seconds.
mifs[7]: 5 files, 1 directories
mifs[7]: Total bytes : 258048
mifs[7]: Bytes used : 8192
mifs[7]: Bytes available : 249856
mifs[7]: mifs fsck took 0 seconds.
mifs[8]: 5 files, 1 directories
mifs[8]: Total bytes : 258048
mifs[8]: Bytes used : 8192
mifs[8]: Bytes available : 249856
mifs[8]: mifs fsck took 0 seconds.
mifs[9]: 626 files, 20 directories
mifs[9]: Total bytes : 122185728
mifs[9]: Bytes used : 23486976
mifs[9]: Bytes available : 98698752
mifs[9]: mifs fsck took 29 seconds.
...done Initializing Flash.
Loading "flash:/c2960x-universalk9-mz.150-2a.EX5/c2960x-universalk9-mz.150-2a.EX5.bin"...Verifying image flash:/c2960x-universalk9-mz.150-2a.EX5/c2960x-universalk9-mz.150-2a.EX5.bin.......................................................................................................................................................................................................................................................................................Image passed digital signature verification
File "flash:/c2960x-universalk9-mz.150-2a.EX5/c2960x-universalk9-mz.150-2a.EX5.bin" uncompressed and installed, entry point: 0x3000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.0(2a)EX5, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Mon 16-Feb-15 08:16 by prod_rel_team
HULC:Collect Entropy thread starting on box...
Initializing flashfs...
Using driver version 3 for media type 1
mifs[7]: 12 files, 1 directories
mifs[7]: Total bytes : 1806336
mifs[7]: Bytes used : 834560
mifs[7]: Bytes available : 971776
mifs[7]: mifs fsck took 1 seconds.
mifs[7]: Initialization complete.
mifs[8]: 1 files, 1 directories
mifs[8]: Total bytes : 3870720
mifs[8]: Bytes used : 971264
mifs[8]: Bytes available : 2899456
mifs[8]: Initialization complete.
mifs[9]: 5 files, 1 directories
mifs[9]: Total bytes : 258048
mifs[9]: Bytes used : 8192
mifs[9]: Bytes available : 249856
mifs[9]: mifs fsck took 1 seconds.
mifs[9]: Initialization complete.
mifs[10]: 5 files, 1 directories
mifs[10]: Total bytes : 258048
mifs[10]: Bytes used : 8192
mifs[10]: Bytes available : 249856
mifs[10]: mifs fsck took 0 seconds.
mifs[10]: Initialization complete.
mifs[11]: 626 files, 20 directories
mifs[11]: Total bytes : 122185728
mifs[11]: Bytes used : 23486976
mifs[11]: Bytes available : 98698752
mifs[11]: mifs fsck took 1 seconds.
mifs[11]: Initialization complete.
...done Initializing flashfs.
FIPS: Flash Key Check : Begin
FIPS: Flash Key Check : End, Not Found, FIPS Mode Not Enabled
POST: MA BIST : Begin
POST: MA BIST : End, Status Passed
POST: TCAM BIST : Begin
POST: TCAM BIST : End, Status Passed
POST: ACT2 Authentication : Begin
POST: ACT2 Authentication : End, Status Passed
extracting front_end/front_end_ucode_info (43 bytes)
SM: Detected stack cables at PORT1
Waiting for Stack Master Election...
SM: Waiting for other switches in stack to boot...
SM: All possible switches in stack are booted up
POST: Inline Power Controller Tests : Begin
POST: Inline Power Controller Tests : End, Status Passed
POST: Thermal, Fan Tests : Begin
POST: Thermal, Fan Tests : End, Status Passed
POST: PortASIC Stack Port Loopback Tests : Begin
POST: PortASIC Stack Port Loopback Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
POST: EMAC Loopback Tests : Begin
POST: EMAC Loopback Tests : MAC Loopback Passed
POST: EMAC Loopback Tests : PHY Loopback Passed
POST: EMAC Loopback Tests : End, Status Passed
Election Complete
Switch 1 booting as Master
Waiting for Port download...Complete
Initializing Port Extension Feature Support...
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960X-24PS-L (APM86XXX) processor (revision F0) with 524288K bytes of memory.
Processor board ID FCW1918B171
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
28 Gigabit Ethernet interfaces
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : B0:7D:47:4A:9C:00
Motherboard assembly number : 73-15972-02
Power supply part number : 341-0528-01
Motherboard serial number : FOC191769AD
Power supply serial number : LIT191200UX
Model revision number : F0
Motherboard revision number : C0
Model number : WS-C2960X-24PS-L
Daughterboard assembly number : 73-14200-03
Daughterboard serial number : FOC1917879A
System serial number : FCW1918B171
Top Assembly Part Number : 800-41469-01
Top Assembly Revision Number : C0
Version ID : V02
CLEI Code Number : CMMLR00ARB
Daughterboard revision number : A0
Hardware Board Revision Number : 0x12
Press RETURN to get started!
*Mar 1 00:00:23.893: Read env variable - LICENSE_BOOT_LEVEL =
Mar 30 01:27:38.150: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c2960x_lanbase Next reboot level = lanbase and License = lanbase
Mar 12 05:26:47.933: Flexstack module is 1
Mar 12 05:29:54.649: %STACKMGR-4-SWITCH_ADDED: Switch 1 has been ADDED to the stack
Mar 12 05:29:56.212: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
Mar 12 05:29:56.212: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
Mar 12 05:29:57.826: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
Mar 12 05:30:01.238: %SYS-5-CONFIG_I: Configured from memory by console
Mar 12 05:30:01.311: %STACKMGR-5-SWITCH_READY: Switch 1 is READY
Mar 12 05:30:01.311: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state DOWN
Mar 12 05:30:01.311: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 1 has changed to state DOWN
Mar 12 05:30:02.230: %PLATFORM-6-FLEXSTACK_INSERTED: FlexStack module inserted in Switch 1.
Mar 12 05:30:02.255: %STACKMGR-5-MASTER_READY: Master Switch 1 is READY
Mar 12 05:30:02.499: %SYS-5-RESTART: System restarted --
Mar 12 05:30:02.513: %SSH-5-ENABLED: SSH 1.99 has been enabled
Mar 12 05:30:04.254: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to down
Mar 12 05:30:04.282: %USB_CONSOLE-6-MEDIA_RJ45: Console media-type is RJ45.[OK]
Mar 12 05:30:17.966: %PKI-6-AUTOSAVE: Running configuration saved to NVRAM
Switch>
Switch>
Switch>
Switch>en
Switch#
Switch#
Switch#
Switch#sh sw
Switch#sh switch ?
<1-8> Switch Number
detail show detailed information about the stack ring
neighbors show each switch's neighbors
stack-ports show the status of the stack ports
stack-ring show stack ring
| Output modifiers
<cr>
Switch#sh switch nei
Switch # Port 1 Port 2
1 None None
Switch#
Switch#
Switch#
CPU rev: B
Board rev: 18
Testing DataBus...
CPU rev: B
Board rev: 18
Testing DataBus...
USB EHCI 1.00
USB EHCI 1.00
USB Console INIT
executing...
cisco Systems, Inc.
Election Complete
export@cisco.com.
Version ID : V02
Switch>
Switch>
Switch>
Switch>en
Switch#
Switch#
Switch#
Switch#sh sw
Switch#sh switch ?
<1-8> Switch Number
| Output modifiers
<cr>
1 None None
Switch#
Switch#
Switch#
CPU rev: B
Board rev: 18
Testing DataBus...
