arp inspection without dhcp
dreams_as_money
Hey mates
I hope you are doing well
so i have a question could  someone  assist me?
we have  switched topology  and  I want to implement arp inspection with no-dhcp
while configuring production  topology I got several problems
I have  server that have  several interfaces
I have  servers that configured micro. NLB with virtula mac addres
I have Blade system that have several server also dns   and etc.
while  configuring arp inspection i got lots of problems
so I need to bind  several ip  to mac  in one interface and  prevent  arp spoofs  etc.
and  also  to prevent users who  can  change  its ip to server ip in other  word  prevent ip conflict
in interface  which connected to nlb  crying  abt   invalid arp also in pther server which has several interfaces
any idea? how I should manage  this  problem
Config...
ip arp inspection vlan 8
ip arp inspection validate src-mac ip
ip arp inspection log-buffer entries 512
ip arp inspection filter av8 vlan  8
arp access-list av8
permit ip host*************     mac host********
permit ip host ****************mac host *************
permit ip host ****************mac host**************
permit ip host **************  mac host ***************
Peter Paluch
Your idea is correct - you define a static IP-to-MAC ARP access list and use it in the Dynamic ARP Inspection configuration. Even the configuration snippet you've provided seems to be correct. Do you feel it is not working as expected for you?
Best regards,
Peter
Hi Peter
Its working good but only with end hosts
with server which has several interfaces it gives errors invalid  arp or dhcp snooping  problem
I want  to implement arp inspection with server  which has several interfaces or nlb
but it disbles it after pps  expired  I configured pps to 100 but  it gives me lots of  arp errors
How can I mange such problem I mean checkin the error types in cisco  page it says that its  an arp spoofing and how can I make sure if  there arp spoofing in my local lan
I am not sure that it should be spoofing
