ARP TIMEOUT
dacruzer1
How do you show the current arp timeout on router.  I have a 3825 and a 2811.
Thanks in advace.
Alfred
John Blakley
Arp timeout can be found per interface when you do a "show int | i ARP"
Router(config)#do sh int fa0/1 | i ARP
You can change it per interface with the "arp timeout " command on the interface. Default is 4 hours...
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
John Blakley
HTH,
John
Thanks John, that works !
