ASA 5510 Setup Communication between two interfaces
dhavalp
I'm a newbie to Cisco world so bare with me -- We have an ASA 5510 -  I'm doing all configurations through the ASDM not CLI.  So please excuse my ignorance.
Eth0/0 - WAN
Eth0/1 - LAN (10.0.0.0/24) (99 Security Level)
Eth0/3 - GuestWifi (10.0.40.0/24) (99 Security Level)
The goal is to have Eth0/3 use the internal DNS server in the Eth0/1 interface to resolve DNS queries.  I've attempted to configure NAT Exempt
Interface - GuestWifi
Source - Any
Destination - LAN
NAT Exempt Direction - Nat Exempt inbound traffic from interface TTCGuest to higher security interfaces.
Also - configured Access Rules to allow DNS traffic 53 UDP.
Nothing is working, what am I doing wrong.
Thanks in advance!
D
15 Replies 15
Thanks for posting the running config. This is helpful. You tell us that packet tracer shows it fails in NAT. But that does not seem to be what you posted which is
Info: (acl-drop) Flow is denied by configured rule
It is interesting that when you select show rule in NAT that it shows that it seems to be involving LAN to WAN. Perhaps we can investigate this. But first there is a different issue that you need to address.
I see this line on the config
access-group GuestWifi_access_in in interface GuestWifi
But the access list that it references is not in the config that you posted. Either configure the access list or remove the access-group command.
Rick
Rick
