ASA issue with either routing or ACL or NAT...
dovla091
I am configuring ASA for the first time. Usually I was playing with Cisco switches, HP switches and Cisco routers, but eventualy time comes for me to play with ASA. The network goes like this.
On HP switch there is two networks:
- admin (192.168.1.0/24 VLAN1)  (ports untagged 13-23)
- guestWifi (192.168.10.0/24 VLAN10) (ports untagged 1-12)
Tagged trk port (24) to pass VLAN 1 and VLAN 10 to ASA, and this is done just fine
HP Configuration:
show running-config
Running configuration:
; J9773A Configuration Editor; Created on release #YA.15.16.0006
; Ver #06:04.9c.63.ff.37.27:12
hostname "MDF-XXXX"
trunk 24 trk1 lacp
timesync sntp
sntp unicast
sntp 30
sntp server priority 1 194.239.123.230
snmp-server community "public" unrestricted
vlan 1
   name "XXXX-ADMINISTRATION"
   no untagged 1-12
   untagged 13-23,25-28
   tagged Trk1
   ip address 192.168.1.254 255.255.255.0
   ip helper-address 192.168.1.1
   exit
vlan 10
   name "XXXX-GUEST-WIFI"
   untagged 1-12
   tagged Trk1
   ip address 192.168.10.254 255.255.255.0
   ip helper-address 192.168.10.1
   exit
spanning-tree
spanning-tree Trk1 priority 4
no tftp server
no dhcp config-file-update
no dhcp image-file-update
password manager
I have setup the configuration for ASA as interface 1/1 to be outside with static IP of 93.164.15.50/30 and interface 1/2 to have two subinterfaces each per specific VLAN (so, gi1/2.1 - VLAN1 and gi1/2.10 - VLAN10) and ping from switch to ASA works flawlessly.
I have setup one default route as 0.0.0.0 0.0.0.0 93.164.15.49 1 which is the line between ASA and ISP box, when I try to ping from pc that simulates "gateway" to ASA, everything works as it should, but when I try to ping from switch to outside interface of ASA on IP 93.164.15.50/30 then I get no reply. Even thoug we are speaking of ICMP protocol, I presume that this also applies to all other traffic TCP/UDP.
ASA configuration:
 show running-config
: Saved
: Serial Number: JAD20230482
: Hardware:   ASA5506, 4096 MB RAM, CPU Atom C2000 series 1250 MHz, 1 CPU (4 cores)
ASA Version 9.5(2)
hostname xxxxxxxxxx
enable password ciqYWBUSFqxNA58M encrypted
xlate per-session deny tcp any4 any4
xlate per-session deny tcp any4 any6
xlate per-session deny tcp any6 any4
xlate per-session deny tcp any6 any6
xlate per-session deny udp any4 any4 eq domain
xlate per-session deny udp any4 any6 eq domain
xlate per-session deny udp any6 any4 eq domain
xlate per-session deny udp any6 any6 eq domain
names
interface GigabitEthernet1/1
 description Outside interface for connecting to ISP box
 nameif outside
 security-level 0
 ip address 93.164.15.50 255.255.255.252
interface GigabitEthernet1/2
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/2.1
 description administration office network
 vlan 1
 nameif administration
 security-level 100
interface GigabitEthernet1/2.10
 description guest wifi network
 vlan 10
 nameif guestWifi
 security-level 100
 ip address 192.168.10.1 255.255.255.0
interface GigabitEthernet1/3
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/4
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/5
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/6
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/7
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/8
 shutdown
 no nameif
 no security-level
 no ip address
interface Management1/1
 description Management of the ASA via ASDM
 management-only
 nameif Management
 security-level 80
 ip address 192.168.2.1 255.255.255.0
ftp mode passive
object network administration
 subnet 192.168.1.0 255.255.255.0
 description administration network
object network guestwifi
 subnet 192.168.10.0 255.255.255.0
 description guest wifi zone
object network defaultRoute
 subnet 0.0.0.0 0.0.0.0
 description Default route
object-group network Inside_Networks
 description All Inside xxxxxx Networks
 network-object object administration
 network-object object guestwifi
pager lines 24
logging enable
mtu Management 1500
mtu administration 1500
mtu guestWifi 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
icmp permit 192.168.1.0 255.255.255.0 administration
icmp permit 192.168.1.0 255.255.255.0 guestWifi
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (any,outside) source dynamic Inside_Networks interface description Nat translation for xxxxx for all networks
route outside 0.0.0.0 0.0.0.0 93.164.15.49 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 sctp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable
http 192.168.2.0 255.255.255.0 Management
no snmp-server location
no snmp-server contact
service sw-reset-button
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpoint ASDM_TrustPoint0
 enrollment self
 subject-name CN=xxxxxx.xx
 keypair tokaicert.key
 proxy-ldc-issuer
 crl configure
crypto ca trustpoint ASDM_Launcher_Access_TrustPoint_0
 enrollment self
 fqdn none
 subject-name CN=192.168.2.1,CN=xxxxxASA
 keypair ASDM_LAUNCHER
 crl configure
crypto ca trustpool policy
crypto ca certificate chain ASDM_TrustPoint0
 certificate 7fd59157
    30820339 30820221 a0030201 0202047f d5915730 0d06092a 864886f7 0d010105
    0500302c 3111300f 06035504 03130874 6f6b6169 2e646b31 17301506 092a8648
    86f70d01 09021608 546f6b61 69415341 301e170d 31363037 32323039 31353534
    0a00eae3 c1e13963 faa26a89 5fff7ee3 77f6bffc d373dc5c 75bd1db8 7a5f27bf
    f2f3aff7 a279c32e f174c6b5 c5f37dc9 4fbaa003 ded7161a 787f4e6f caad57b3
    1dfb9fe0 c3cc990f c11bc06f c142379d 1b91f5cb c10fc89a 6fcf5d49 39679a77
    087c68cf 8b6c803b 29c8a084 77baf819 78bac258 67c3b38c 65d28a7c df
  quit
crypto ca certificate chain ASDM_Launcher_Access_TrustPoint_0
 certificate 80d59157
    308202ce 308201b6 a0030201 02020480 d5915730 0d06092a 864886f7 0d010105
    05003029 3111300f 06035504 03130854 6f6b6169 41534131 14301206 03550403
    130b3139 322e3136 382e322e 31301e17 0d313630 37323231 31303532 385a170d
    32363037 32303131 30353238 5a302931 11300f06 03550403 1308546f 6b616941
    c8a71d39 a28b574b ae2d2a13 48cbca81 207f2455 1854a334 da51685a af280634
    2b397dc1 d237d294 7687145d da038bfa 418824f5 74b666a8 892572e5 85f550fd
    676612f8 4587203a fef23deb 263b8788 235b09f7 d61f8f62 59ec8f81 2ca964ff
    8074643a 47b551bb dd059fb8 a621da24 76651c7e 25d2686b 1da35983 beca326f
    3996fe1e b56ff5e8 1dbb18c9 6723d809 6b0e
  quit
telnet timeout 5
ssh stricthostkeycheck
ssh 192.168.1.0 255.255.255.0 administration
ssh 192.168.10.0 255.255.255.0 guestWifi
ssh timeout 5
ssh version 2
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd address 192.168.1.2-192.168.1.253 administration
dhcpd dns 8.8.8.8 208.67.222.222 interface administration
dhcpd enable administration
dhcpd address 192.168.10.2-192.168.10.253 guestWifi
dhcpd dns 8.8.8.8 208.67.222.222 interface guestWifi
dhcpd enable guestWifi
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ssl trust-point ASDM_Launcher_Access_TrustPoint_0 Management
ssl trust-point ASDM_Launcher_Access_TrustPoint_0 Management vpnlb-ip
dynamic-access-policy-record DfltAccessPolicy
username fellow password xxxxxxxx encrypted privilege 15
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
policy-map type inspect dns migrated_dns_map_1
 parameters
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
 profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
password encryption aes
Cryptochecksum:xxxxxxxxxxxxxxxxxxxxx
: end
Can anyone explain where is the problem, because I cannot see it. Also if someone has some emulator or what, can you give me the correct answer what is missing in ASA. The reason for that is I am running production machine and I cannot do "try this, or try that". I hope you understand that.
Thank you in advance and have a great weekend :)
Hey [@dovla091@gmail.com],
To 'truncate' something means to shorten it, it is nothing to do with trunking VLANs. Your ASA configuration looked a little short, so I was just making sure we had the full configuration so I can get the best understanding of your setup. I feel your pain brother, when I made the move from working with Cisco LAN technologies into ASAs and security it was a lot to learn, but the fundamental behaviour is the same and you will pick it up fast.
I have had some spare time today to recreate your setup in my lab environment to see what is missing. I managed to get it to work almost immediately, so please read and consider the below points carefully and we will be able to get this working for you. I understand that you may not need ICMP, but if we can get ICMP working as a test then we can begin to allow other protocols through to get this fully working for you as per your design.
1. In my last post to you I made a typing error, your NAT statement should read the below example. You are correct that you should eventually be able to use "(any,outside)" instead of "(administration,outside)" in the statement and it'll work the same - I am just trying to simplify things to get this working from VLAN1 (administration) to prove connectivity. Please amend your statement to the following.
nat (administration,outside) source dynamic 192.168.1.0 255.255.255.0 interface
2. You are correct that traffic can flow from higher security level interfaces to lower security levels successfully, so in your case traffic is allowed to flow from the inside interface (nameif administration) to the outside interface (nameif outside). However, the traffic will not be able to flow back unless we use one of the following methods to allow it back through. This is part of your issue.
  1. Stateful inspection on the protocol of the traffic on its way out, this way when it needs to come back through to the inside it can bypass the security of the outside interface as it is deemed as inspected/safe. Currently, your firewall is not inspecting any traffic.
  2. An access control list permitting that particular protocol to come back through. Currently you have no access control list on your outside interface permitting this which explains why echo-replies are being DROPPED.
To remedy this, I can walk you through getting inspection working, but for  the moment to prove end to end connectivity please apply the following commands to your ASA, this will allow the ICMP echo-reply back through.
1. Create an access control list permitting ICMP from ANYWHERE to ANYWHERE and include logging to help with future diagnosis.
access-list OUTSIDE_ACCESS_IN extended permit icmp any any log
2. Apply the newly created access control list as an ingress direction to your outside interface.
access-group OUTSIDE_ACCESS_IN in interface outside
Now you should be able to ping through the firewall to the ISP router on 93.164.15.49 and received a reply. Note that you will still be unable to ping the outside address of the ASA, this is fairly standard practice - we can remedy this too if required. Please action my suggestion above and test... I look forward to hearing how you get along.
Luke
* Things to bear in mind:
- You will not be able to ping the outside interface of your ASA directly as traffic cannot flow from security level 0 to security level 100 without an ACL. Not being able to ping the outside address is fairly standard practice. You will be able to ping out on the WAN through the firewall however.
- ICMP is not natively a stateful protocol.
- If there is no ACL on the outside interface, it will block all traffic by default unless it is inspected, otherwise know as an implicit deny rule.
Please rate helpful posts and mark correct answers.
20 Replies 20
Luke Oxley
Hi Luke,
not sure what do you mean by it is not truncated? The configuration on the switch is trunkated via port 24. It passes both vlan1 and vlan10 (if I am not wrong...?) Also what I have learned is that on ASA you don't have "switchport trunk", instead you create subinterface and you add that to specific VLAN. In my case I could ping inside interface without any issues, but when I wanted to ping outside interface, I could not do it. There are no ACL list on outside interface, and honestly I don't know how ASA is working. I had pleasure to work with switches and routers, and access lists are the least thing that I used (simply because there are other security protections on higher layers, so I didn't bother myself with that, plus in case of troubleshooting network issues, I would make my life even harder...). Anyway, the goal is that I need to configure ASA to pass all the traffic from inside network, and restrict access from outside to inside network. From inside to outside, there is no need for ACL since traffic should be able to freely pass from higher security value eg. 100 to lower security value of 0 (outside), so I am not sure if the ACL is needed. By my logic, fw that passes traffic from inside network, should automatically allow same traffic to go inside (an reply from other servers...).
What it caught my attention is the NAT. In many examples, people were using (inside, outside), and in my case I was using object (any)...? Technically speaking it should allow NAT to function correctly, but again, I don't know how ASA behaves in specific situation under specific rule.
So to answer your question:
1. Are you able to ping the ISP next hop at 93.164.15.49 from your PC which sits behind the ASA?
NO, unfortunately, the ping is not passing through... and honestly I am not sure why.
2. Can you please amend your only NAT statement to read the following:
nat (inside,outside) source dynamic Inside_Networks interface
This is not correct in my case, the difference is the nat (any, outside) and I am not sure is there any difference in ASA behavior...?
3. We need ICMP stateful inspection enabled since you have an implicit deny on the outside. Please can you add ICMP to your policy map?
Actually I don't need ICMP. This was only used for testing. My only concern is that all the network traffic from inside can travel to outside and that fw should allow "reply" back to inside network. All other requests from outside should be banned (such as scans, or penetration attempts).
I will try tomorrow to change NAT rule, and hopefully I don't need to use ACL for outside to inside.
Luke
Hi Luke,
sorry for not replying sooner. My boss has used power adapter from ASA5506X to another site, so I am not able to do it - right now. I will try this as soon as possible. I see the point were you need to allow traffic from outside to inside, and that is what I was bit curious. I didn't know if the ASA do it dynamically when it sends the traffic, it automatically see the outside ip address and appends the rule to allow the traffic, or I need to do it manually. Second thing that I need to ask you. Since there are two VLANs involved (or should I say two subinterfaces on GigabitEthernet 1/2 - 1/2.1 and 1/2.10)
by your NAT rule - last keyword interface:
I presume that I need to set name of the interface like "administration" or "guestWifi" correct?
The same question applies to the access list:
Last and not least,
I found that I am missing a static route for network 93.164.15.48/30
correct me if I am wrong, but this is also needed or not? I know that you will probably have in the routing table record where it says C - "directly connected", but I am not sure if this would be enough for router to know the path to the gateway ip address or not?
P.S. I don't know if I need to mention, I am running ASA5506X with firepower. Is there a difference between ASA5506X with workflow from standard firewall where you use only fw rules and firewall with firepower services which is basically additional layer of security with IDS/IPS on board...?
Best regards
Hi [@dovla091@gmail.com],
No problem. Yes, correct, the ASA will not dynamically allow the traffic to flow back from security level 0 without either an ACL permitting it or stateful inspection. Please see my answer to your questions below.
A) In answer to your NAT question, yes, the word "administration" refers to the nameif of the sub-interface. As I mentioned, I was keen just to get VLAN1 up and running for now to prove connectivity and routing. After we've fixed this, we can then change the NAT statement to "any" to start NAT'ing the guest traffic too.
B) In answer to your ACL question, yes, that rule is telling the ASA to apply the ACL "OUTSIDE_ACCESS_IN" to the outside interface in an ingress direction. The word "outside" at the end of the rule is matched to the nameif of the interface.
C) In answer to your routing question, no, you are not missing a route as the 93.164.15.48/30 network is a directly connected route so will already be in your routing table. Also, the traffic already knows how to break out by using your default route under the command "route outside 0.0.0.0 0.0.0.0 93.164.15.49 1" which will send it to the ISP router or gateway of last resort.
D) In answer to your FirePower question, it is irrelevant. Think of FirePower (the function of IDS/IPS) as a separate module. The firewall side of things is what we are dealing with in this post and this will have the same behaviour with our without the FirePower module installed.
As per my last post, please action the needed changes when you get a chance and let me know how you get on. Look forward to hearing back.
Cheers,
Luke
Hi Luke, you will probably go nuts with all my questions. Regarding C) I was not too sure, but thanks for confirming this :) Regarding your answer D) I believe that this would only apply if the traffic is not redirected to firepower module. As I understood, if you do a redirection of the traffic to SFR module, than this might not apply. Any additional rule might cause to drop packets and not to forward them front, correct?
If so, than I need to make sure not to use SFR module (for now), until I don't chew all the ASA documentation and books regarding additional SFR module :)
No problem brother. Yes potentially this could happen depending on what your policy states of course. Perhaps it is best to leave the SFR un-configured until we get the basics working first.
Let me know when you've had a chance to test those changes and we will go from there.
Cheers,
Luke
Hi Luke,
Unfortunately, no. Last few day I was pretty busy. :( We've got a new power adapter today, and I was mostly on site, so haven't had a chance. Even though I was reading some articles regarding configuring ASA, and more I read, more confusing it is. For example. You've mentioned that I am probably missing access-list, but on all examples even on video tutorials ASA 101, they configure: interfaces, ip address, vlans, default route and NAT. They haven't mention access-lists nor they have setup one, and the traffic was passing through and getting back without any problem. How come that in their case it is going through and in mine, it is not working?
Example:
https://www.youtube.com/watch?v=F6qvKRFn-xc
They are using ASA 5505 and my model is ASA5506X.
Is there a difference?
No problem mate - it is confusing stuff, ASA is a complicated bit of code.
The most likely reason their traffic was flowing is because of stateful inspection as part of their basic setup. So if a computer behind the NAT on the LAN tries to access Google, the firewall will inspect the packet on the way out, so that when the return traffic comes back from Google it will not need an access control list to allow it back through or it will bypass the access control lists if there is one applied. As the return traffic is inspected it will see it as "safe".
The reasons I have suggested for you to create an access control list are:
  1. It is best practice to, else, what is the point of having a firewall over a standard router?
  2. As we are connecting directly to the firewall from the outside, the traffic will not have the chance to be inspected, so we must specify this in an access control list and allow it.
I hope that makes sense and good luck with the testing :-)
Luke
Hi Luke,
"B. As we are connecting directly to the firewall from the outside, the traffic will not have the chance to be inspected, so we must specify this in an access control list and allow it."
With second line, you've lost me. Perhaps I might not understood you correctly:  I am not trying to connect from outside (like access server via some port or whatever - even though this will probably come in future...). I am just planning to do this (for now):
- To allow users from inside to go where ever they please, and deny attacker from outside to access the internal network.
- Set VPN Anyconnect to allow me from outside to get into internal network (If I need to fix something by remote)...
This is why I am bit confused. If you are tying to get outside, firewall should inspect packets and say: "this is from higher priority - safe network, I will allow packets, and on return, it should in theory look for the destination IP address and connect the dots that this traffic is initiated by user from inside network, and let it through". I know that ACL is great layer of security if you wish to "ban or allow" people from outside to go in, but it is quite strange that I need to implement ACL for internal network users just so they can go out and browse webpages on the internet...
Please correct me if I am wrong.
P.S. I bought 3 books with value of 150€. I hope they will help me understand, what is happening in the background on that device :)
You are absolutely correct that you do not need an access control list on the outside just to pass through inside traffic to Google for example because as the traffic is inspected on the way out (providing inspection is configured correctly) it will allow it back through as it is considered "safe". However, if you wish to use AnyConnect as you say, you'll need an access control list for that because as the traffic is being initiated from the outside (AnyConnect VPN Client) and thus it will not be pre-inspected. Not to mention, it's as per Cisco best practice to have an access control list anyway, even if it is not explicitly needed it isn't going to harm your configuration and traffic flow and it will be needed later on for static PAT'ing to servers and running your AnyConnect service as you say. I hope that helps :-)
Any of the Cisco certified books are expensive, but I'm my opinion good value for money. Good luck with your studies and testing when you get around to it!
Luke
Hi Luke.
I will quote:
Yes, this is where it starts to be weird. It doesn't allow traffic to go outside from inside. Last time I have placed wireshark to pickup anything that is going from external IP address, and I caught nothing. It is like no traffic were sent from firewall to another (outside) machine...
On Monday, I will try to simulate once again, and I will paste my current configuration. I newer worked with ASA but I know how in theory it should work (by simply applying logic), and this device is behaving quite odd... :(
Provided you follow my command sets that I suggested up above, this should get you working. As I say, have a test and let me know how you get along.
Luke
Hi Luke,
I will try it on Monday when I come to the office and I will let you know.
thank you once again for the help and have a great weekend
