ASR1001-X rate limiting via RADIUS
albertofreire
Hi there!
I've a doubt about qos from radius attributes (avpair).
I've configured on Freeradius the avpair attribute radius "ip:sub-qos-policy-in=10DFIN"and I make a pppoe teste connection...
The user is connected, but I don't able see if policy-map is working:
auth.router.dc01#sh policy-map 10DFIN
  Policy Map 10DFIN
    Class UP
     police cir 8192000 bc 256000
       conform-action transmit
       exceed-action drop
auth.router.dc01#sh policy-map summary
 Total number of policies configured: 4 (Active: 0, Maximum: 16000)
 Number of CLI configured policy-maps: 4 (Active: 0)
 Number of Non-CLI configured policy-maps: 0 (Active: 0)
[does nothing to show]:
auth.router.dc01#sh policy-map interface
auth.router.dc01#
[There is information about policy-map in this command]:
auth.router.dc01#sh subscriber session username ramboiv
Type: PPPoE, UID: 213, State: authen, Identity: ramboiv
IPv4 Address: 172.31.100.16
Session Up-time: 00:35:25, Last Changed: 00:35:25
Interface: Virtual-Access2.1
Switch-ID: 4624
Policy information:
  Authentication status: authen
Classifiers:
Class-id    Dir   Packets    Bytes                  Pri.  Definition
0           In    0          0                      0    Match Any
1           Out   0          0                      0    Match Any
Features:
QoS Policy Map:
Class-id    Dir   Policy Name Source
0           In    10DFIN      Peruser
Configuration Sources:
Type  Active Time  AAA Service ID  Name
USR   00:35:25     -               Peruser
INT   00:35:25     -               Virtual-Template123
auth.router.dc01#
Can you help to understand whether that policy-map going to work?
Thanks!
0 Replies 0
