assigning addiitional Watts to switch Port
vsewpersad
I have an old 2960C-12PC-l switch. I only have 3 wireless access points on it, which 2 of uses, 15.4w. I want to force my 3 port to give me 30w. is this possible? there is nothing else on the switch.
Mark Malone
Hi i think your limited to 12 looking at the doc per port
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-c-series-switches/data_sheet_c78-639705.html
You could try this below but it may not be there , if not you cant increase sorry
SUMMARY STEPS
1. configure terminal
2. interface interface-id
3. power inline {auto [max max-wattage] | never | static [max max-wattage]}
4. end
5. show power inline [interface-id | module switch-number]
Table 1.       Available Cisco Catalyst Compact Switch models
Model
Ethernet Ports
PoE
Output Ports
Available
PoE Power
Uplinks
MACsec
2960C-8TC-L
8 x 10/100
Fast Ethernet
N/A
2 x 1G copper or 2 x 1G SFP
N/A
2960C-8TC-S
8 x 10/100
Fast Ethernet
N/A
N/A
2960CPD-8TT-L
8 x 10/100
Fast Ethernet
N/A
2 x 1G
(PoE+ input)
N/A
2960C-8PC-L
8 x 10/100
Fast Ethernet
8 PoE
124W
N/A
2960CPD-8PT-L
8 x 10/100
Fast Ethernet
8 PoE
Up to 30.8W[1]
2 x 1G
(PoE+ input)
N/A
2960C-12PC-L
12 x 10/100
Fast Ethernet
12 PoE
124W
N/A
2960CG-8TC-L
8 x 10/100/1000 Gigabit Ethernet
N/A
N/A
3560C-8PC-S
8 x 10/100
Fast Ethernet
8 PoE+
124W
N/A
3560C-12PC-S
12 x 10/100
Fast Ethernet
12 PoE+
124W
N/A
3560CG-8TC-S
N/A
Yes
3560CG-8PC-S
8 PoE+
124W
Yes
3560CPD-8PT-S
8 PoE
Up to 23.8W[2]
2 x 1G
(PoE+ input)
Yes
Leo Laohoo
Post the complete output to the command "sh power inline".
Reza Sharifi
2960C-12PC-l comes with standard POE (15.4w max per port) and you can't combine multiple ports to get 30w.
