Bandwidth Control
saquib.tandel
I get 8MB Bandwidth from service-provider and need to distribute to different departments on the floor. All departments are on different VLAN.
Dept1=4MB
Dept2=2MB
Dept3=1MB
Dept4=512kb
Dept5=512kb
service-provider >>> Internet_RTR >>> Switch
On Switch I create 5VLANS, what more steps is needed to restrict bandwidth
5 Replies 5
Nagendra Kumar Nainar
You can use Hiererichal QoS to acheive the same.
Configure a parent policy to shape the total traffic to 8 Mbps as below,
policy-map INTERNET_TRAFFIC
class class-default
shape average 8Mbps
Now configure the child policy with bandwidth for each department as below,
class-map DEPARTMENT1
match access-group name
class-map DEPARTMENT2
policy-map TRAFFIC_CLASS
class DEPARTMENT1
bandwidth
class DEPARTMENT2
bandwidth
Now apply the child policy to parent policy as below,
class class-default
service-policy TRAFFIC_CLASS
HTH,
Nagendra
Joseph W. Doherty
If your concern is allocation of inbound bandwidth (re: "service-provider >>> Internet_RTR >>> Switch"), you might define a CBWFQ policy with policers that limits the traffic to each department. However, although such a policy will indeed limit the traffic that can reach any one dept., it may not truly regulate inbound bandwidth utilization since the policer would be downstream of the 8 Mbps link's bandwidth. Such a policy (or perhaps one using shaping or minimum class guarantees) generally work better when placed upstream of the bandwidth congested point (i.e. the ISP's side of the link).
For outbound, I too would suggest something similar to Nagendra's post although per dept. shaping or policing might also be used. (NB: Nagendra's post is also similar to what I would suggest for ISP egress [to you]. [One possible major improvement, if using 12.4.20T or later, would be to also add FQ to each class.])
PS:
BTW, I believe both Nagendra and I assume you control the "Internet_RTR". If not, depending on the switch features, you might implement policing there too but syntax and feature support usually much different.
Internet Router is controlled by us.
IOS version is 12.4 on Router
IOS version on L2Switch is 12.2
Internet Router is terminated to a L2Switch and then connected to department switches.
what configuration changes are needed on L2switch to restrict Bandwidth.
My concern is inbound and outbound traffic restriction. can this be achieved on L2Switch
Depends on the capabilites of the switch. Most that could might only offer policing and usually not as well featured as the router. Also, again, for inbound, routers and switches QoS features are not overly useful for regulating bandwidth on the inbound link (except, again, amount of bandwidth that reaches ends hosts - not exactly the same thing).
PS:
With TCP traffic, there are some 3rd traffic shaping appliances that can do more with inbound traffic regulation (generally by spoofing a host's RWIN and/or shaping ACKs).
