Best practices for VLANs implementation
pep87
Hi everybody. TI am studying a Engineer Networking degree on Collage. I would like to know best practices for implementing VLANs. I am  newbie. Some questions:
1- Shoud i create a independent vlan for IT department or i can integrate it with Administration vlan?
2-In case of Administration vlan, i know this vlan is used to manage network devices like switches and routers, but i need to design a small corporate network, i should create an administration vlan for the HQ and for each branch or i can use the same administration vlan on all locations?
3- i am going to use layer 3 switch for LAN intervlan routing on each branch and on HQ, I know i have to define the gateway of the administration vlan on the layer 3 switch of each location but how i have to setup the router of each location  for assigning an ip which belongs to the administration vlan?
4- In my design, branches and HQ wil have some common departments like IT department, Finance department, Sales department, etc. How i shoud setup vlans for each departments? can i extend vlans over the corporate WAN ? or i shoud create these vlans on each site?
5- If i i shoud create these vlans on each site,  can i use the same number and name of vlan on each site for example vlan 10 for Finance department on HQ and vlan 10 for Finance department on the branches? and how these vlans will communicate between them (for example how i will communicate Finance vlan 10 of HQ with Finance vlan 10 of the branches)?
Thanks in advance
Julio E. Moisa
A best practice is create a VLAN ID for each department, it will separate the broadcast domains and it will provide logical security.
Each VLAN is assigned to a network (most of the cases) so if you are using L2 dedicated links between HQ and branches, you can use the same VLAN with same network but in the most of cases HQ and branches are connected with L3 links, in this situation you can use the same VLAN but with different network.
You cannot have 2 gateways with the same network unless you are using VRF, this is the same like the previous question, you can use the same VLAN ID but with different network so for example:
HQ router will have:
VLAN 100 with gateway 172.16.100.1
Branch Router will have
VLAN 100 with gateway 172.17.100.1
It depends, like the question 2.
Yes, you can use the same VLAN ID but remember they will be assigned to different network, they will be able to communicate using routing protocols between Branch and HQ.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Julio E. Moisa
Hope it is useful
Leo Laohoo
Do you want an answer to help you understand or an answer to submit for grades?
The answer to this question will depend entirely upon the nature of the industry to apply it to. Most of the time a VLAN-per-department is generally the "rule of thumb" when dealing with administrative sites, like offices and such.
The minute the boundary crosses over to manufacturing or health, this idea is thrown out the window.
