Broadcast specific static routes on EIGRP
dapogsdapogs
I have EIGRP running on my network with the "redistribute static route" option. Is there a way to filter which static routes are broadcasted over EIGRP as I have some static routes that I don't want to be broadcasted.
Jerry Ye
You can use the route-map option during redistribution to control which networks will be redistributed into EIGRP. The below example will block 10.10.10.0 and 11.11.11.0 while permitting everything else
ip access-list extended BLOCK_STATIC
permit 10.10.10.0
permit 11.11.11.0
route-map STATIC_ROUTES deny 10
match ip address BLOCK_STATIC
route-map STATIC_ROUTES perm 1000
router eigrp xx
redis static route-map STATIC_ROUTES
HTH,
jerry
Jerry Ye
permit 10.10.10.0
permit 11.11.11.0
router eigrp xx
HTH,
jerry
