11-07-2020 06:08 AM - edited 11-07-2020 06:29 AM
Hello !
I'm having a problem with the configuration of a bundle-ether between an A9K and an N3K, the configuration is below.
The bundle doesn't work when I want to use a sub-interface with vlan, but it works without. Do you have an idea?
On A9K :
interface Bundle-Ether1
bundle minimum-active links 1
interface Bundle-Ether1.55
ipv4 address xxx xxx xxx
encapsulation dot1q 55
interface TenGigE0/1/0/7
bundle id 1 mode active
bundle port-priority 1
interface TenGigE0/2/0/7
On N3K :
interface port-channel3
switchport mode trunk
switchport trunk native vlan 55
switchport trunk allowed vlan 55
speed 10000
duplex full
vpc 3
interface Ethernet1/1 & 1/2
speed 10000
duplex full
channel-group 3 mode active
11-07-2020 06:55 AM
- Check the logs on both platforms, when the bundle is intended to get formed or 'started'
M.
11-07-2020 07:06 AM
the problem might be the native vlan. The ASR does not have a 'native' option, but you can add the 'untagged'keyword:
--> encapsulation dot1q 55, untagged
