C1921 issue with CCP
C1921
Hi, I have a strange issue with my C1921 router in that I have set it up so I can reach the homescreen of the CCP Express via a local IP, but when I select any entry on the screen (like Express Setup) there's no response.  When I ran a trace with Fiddler on the browser, it shows "waiting for response".  I can configure just fine via ssh/telnet.
Here's my version of the CCP Express.  I also have the local PC version, but I believe I'm getting the same error (just says discovery failed, but no reason).
Cisco Configuration Professional Express
Cisco Configuration Professional Express 3.2!
which browser and which Java version are you using on your PC ?
Also, post the config of your 1921 router...
HI,
Thanks for the quick reply.
I tried downloading Java 1.61 and put the exception in for the certificate.
I tried in the Vivaldi browser, Internet Explorer, and Brave. It seems the
response from the router doesn't come back. I disabled all my anti-virus as
well, thinking that was it. I don't know how to easily debug the http
communication from the router.
have you tried Chrome ?
Post the full config of your router...
