C3750X power stack configuration
vladakoci
does anyone know if any issues are reported while configuring power stack ? We did several times with 12.2.58SE1 and SE2, sometimes the power stack is created automatically, sometimes needs to be configured manually. Looks like the behavior is not the same. Maybe it depends on the number/type of switches and number/type of power supplies.
Thank you,
Vlad
hobbe
Level 7
Level 7
The only problem i have seen personally with 3750x is that you can shutdown all the powersupplies.
this means that if you have 4 powersupplies on two switches and you shut 3 of them down and save the config and you then shut down the forth the switches will reboot due to powerloss,
It does exactly what you told it to do so i cant realy complain about it, but there should be an extra warning that you are shutting down the last powersupply.
nice feature if for some reason you can not reload the switch.
