c3850:interfaces had lots of output errors
tianwen.zhao
Hello guys,
C3850 interfaces had lots of output error
Here is the show interface output:
C3850#sho interfaces | in protocol | 5 minute | error
TenGigabitEthernet1/0/1 is up, line protocol is up (connected)
5 minute input rate 41720000 bits/sec, 5912 packets/sec
5 minute output rate 42402000 bits/sec, 6084 packets/sec
7 input errors, 7 CRC, 0 frame, 0 overrun, 0 ignored
7208921 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
TenGigabitEthernet1/0/2 is up, line protocol is up (connected)
5 minute input rate 466000 bits/sec, 259 packets/sec
5 minute output rate 1845000 bits/sec, 468 packets/sec
1 input errors, 1 CRC, 0 frame, 0 overrun, 0 ignored
36428916 output errors, 0 collisions, 1 interface resets
TenGigabitEthernet1/0/3 is up, line protocol is up (connected)
5 minute input rate 1157000 bits/sec, 323 packets/sec
5 minute output rate 2829000 bits/sec, 514 packets/sec
117536165 output errors, 0 collisions, 1 interface resets
TenGigabitEthernet1/0/4 is up, line protocol is up (connected)
5 minute input rate 1669000 bits/sec, 676 packets/sec
5 minute output rate 7902000 bits/sec, 995 packets/sec
85216716 output errors, 0 collisions, 1 interface resets
Although there are lots of output errors, but the network function is normal.
thanks,
Leo Laohoo
1. Post the complete output to the "sh interface <PORTS>".
2. What IOS-XE version is the switch (stack) running on?
Dear Leo:
Thank you for you reply
Here is the output:
Hardware is Ten Gigabit Ethernet, address is 2c31.24fb.6e81 (bia 2c31.24fb.6e81)
Description: link to switch(warehouse)
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
reliability 255/255, txload 8/255, rxload 8/255
Keepalive not set
Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseLX SFP
input flow-control is off, output flow-control is unsupported
Last input 00:00:01, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 7262191
Queueing strategy: Class-based queueing
Output queue: 0/40 (size/max)
5 minute input rate 31541000 bits/sec, 4619 packets/sec
5 minute output rate 34268000 bits/sec, 4857 packets/sec
788732990 packets input, 669103675383 bytes, 0 no buffer
Received 755154 broadcasts (682843 multicasts)
0 watchdog, 682843 multicast, 0 pause input
873706206 packets output, 715214436653 bytes, 0 underruns
7262191 output errors, 0 collisions, 1 interface resets
0 lost carrier, 0 no carrier, 0 pause output
Hardware is Ten Gigabit Ethernet, address is 2c31.24fb.6e82 (bia 2c31.24fb.6e82)
Keepalive not set
Last input 00:00:00, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 36752426
5 minute input rate 362000 bits/sec, 193 packets/sec
5 minute output rate 1292000 bits/sec, 364 packets/sec
87426197 packets input, 22522971832 bytes, 0 no buffer
Received 1855052 broadcasts (895866 multicasts)
0 watchdog, 895866 multicast, 0 pause input
190231981 packets output, 113932243833 bytes, 0 underruns
36752426 output errors, 0 collisions, 1 interface resets
Hardware is Ten Gigabit Ethernet, address is 2c31.24fb.6e83 (bia 2c31.24fb.6e83)
Keepalive not set
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 117664013
5 minute input rate 271000 bits/sec, 109 packets/sec
5 minute output rate 563000 bits/sec, 269 packets/sec
69086707 packets input, 25296155901 bytes, 0 no buffer
Received 932604 broadcasts (755102 multicasts)
0 watchdog, 755102 multicast, 0 pause input
164840546 packets output, 96661489883 bytes, 0 underruns
117664013 output errors, 0 collisions, 1 interface resets
Hardware is Ten Gigabit Ethernet, address is 2c31.24fb.6e84 (bia 2c31.24fb.6e84)
Keepalive not set
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 85858444
5 minute input rate 761000 bits/sec, 219 packets/sec
5 minute output rate 1759000 bits/sec, 384 packets/sec
70054673 packets input, 29104546198 bytes, 0 no buffer
Received 930702 broadcasts (729926 multicasts)
0 watchdog, 729926 multicast, 0 pause input
159365800 packets output, 82848512978 bytes, 0 underruns
85858444 output errors, 0 collisions, 1 interface resets
TenGigabitEthernet1/0/5 is up, line protocol is up (connected)
Hardware is Ten Gigabit Ethernet, address is 2c31.24fb.6e85 (bia 2c31.24fb.6e85)
Keepalive not set
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
5 minute input rate 40000 bits/sec, 25 packets/sec
5 minute output rate 156000 bits/sec, 173 packets/sec
11825701 packets input, 1818296472 bytes, 0 no buffer
Received 1809434 broadcasts (1738661 multicasts)
0 watchdog, 1738661 multicast, 0 pause input
87687777 packets output, 10250674412 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
TenGigabitEthernet1/0/6 is up, line protocol is up (connected)
Hardware is Ten Gigabit Ethernet, address is 2c31.24fb.6e86 (bia 2c31.24fb.6e86)
Keepalive not set
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 22371369
5 minute input rate 47000 bits/sec, 38 packets/sec
5 minute output rate 367000 bits/sec, 192 packets/sec
13691012 packets input, 2368187840 bytes, 0 no buffer
Received 1860342 broadcasts (1756035 multicasts)
0 watchdog, 1756035 multicast, 0 pause input
91397529 packets output, 18514001381 bytes, 0 underruns
22371369 output errors, 0 collisions, 1 interface resets
 ......................omit......................................
C3850#sho ver
C3850 uptime is 5 days, 13 hours, 17 minutes
Uptime for this control processor is 5 days, 13 hours, 19 minutes
System returned to ROM by Power Failure
System restarted at 01:43:41 HKT Fri Dec 21 2018
System image file is "flash:packages.conf"
Last reload reason: Power Failure
export@cisco.com.
License Level: Ipbase
License Type: Permanent
Next reload license Level: Ipbase
cisco WS-C3850-12XS (MIPS) processor with 4194304K bytes of physical memory.
Processor board ID FCW2103C1GP
1 Virtual Ethernet interface
16 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
253984K bytes of Crash Files at crashinfo:.
3431232K bytes of Flash at flash:.
0K bytes of Dummy USB Flash at usbflash0:.
0K bytes of at webui:.
Base Ethernet MAC Address : 2c:31:24:fb:6e:80
Motherboard Assembly Number : 73-16285-06
Motherboard Serial Number : FOC21018LAK
Model Revision Number : K0
Motherboard Revision Number : A0
Model Number : WS-C3850-12XS
System Serial Number : FCW2103C1GP
Switch Ports Model SW Version SW Image Mode
* 1 16 WS-C3850-12XS 03.07.04E cat3k_caa-universalk9 INSTALL
Configuration register is 0x102
Raise a TAC Case. I believe this is a very well-known bug, CSCvb65304.
Thank you Leo
