C9200L-48P-4X depth
Adam6225
I have a network cabinet with limited depth that im looking for smaller switches to fit in.
Can anyone tell me the depth of the C9200L-48P-4X with the PWR-C5-1KWAC installed?
The website tells me its 12.9 inches depth. Is this with or without the power supply?
I presume the PWR-C5-1KWAC sits flush with the switch as its a 750watt.
Mark Elsen
 - Ref : https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9200/hardware/install/b-c9200-hig/b-c9200l-hig_appendix_0100.html                              Check Table 3
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Reza Sharifi
Including the PSU and the fans, it is 1.73 x 17.5 x 12.9 in.
I would also add a couple of inches for the power cords.
