Can PagP and static Etherchannel run simultaneously on the same network?
Our network switches are configured to use PagP trunks between them.
I have recently installed a UCS series server for CUCM with two quad NICs and have configured it for NIC teaming on the VM side and on the Cisco side have configured 'static Ether-Channel' (Per Cisco only 'static Ether-Channel' is allowed).
However, since doing so I keep getting flooded with syslog messages that state that the Mac addresses of both the Call Manager and Unity server VMs are flapping between port channels (i.e., the 'static Ether-Channel' and the PAgP Ether-Channels).
Can the PAgP and Static Ether-Channels co-exist simultaneously?  I cannot find any documentation, Cisco or otherwise, that states that they can co-exist simultaneously.
FYI, the load-balancing algorithms for each side is the following:
*VM-side NIC Teaming:  Route Based IP Hash
*Cisco Switches: src-mac
Any assistance would be greatly appreciated.
Reza Sharifi
Having PAGP on the uplink should not effect mode-on on the UCS side. Have you tried LACP on the UCS?
Per Cisco, only the static Ether-Channel (i.e., "on" mode) can be used with NIC teaming on the UCS server.
LACP is not an option on the UCS c-series stand-alone servers.
