Can't connect computers over wireless using RV180W
cristiangroove
Recently we bought a cisco RV180 to manage the company's internal comunications, and also to implement features like VPN.
However we cant even configure the workgroups because the computers cannot see each other in the LAN, this didnt happened previous to the RV180W installation.
Here is a strange issue, when a wifi client tries to ping another wi-fi client the response is a host unreachable. However the following works
-Wired clients can ping wifi clients.
-Wired clients can ping each other.
-Wifi clients can ping wired clients.
It seems tha the problem resides in the wireless configuration, however the router is practically with factory defaults. Only wan and some firewall rules (port forwarding) have been configured.
Any comment is appreciated.
ernesto.niklaus
I found a solution. You need to disable Wireless Isolation within SSID to permit that wireless host can talk each other.
