Can't ping from interface connected to ISP
ps0000000
I have configured 3845 router with dual fail-over ISP. For users in internal network everything is working perfectly. But I have noticed that IP SLA rule 2 is not working as far as from router itself I can't ping any host (including interface IP address 7.1.0.46 itself) and also can't ssh 3845 from outside on interface IP address (7.1.0.46 in my case) with reject result code. But
ping 8.8.8.8 source Gi0/0.2
ping 8.8.8.8 source Gi0/1.10
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
voice-card 0
redundancy
track 22 ip sla 2 reachability
interface Tunnel1
 description T1
 ip address 10.170.171.1 255.255.255.252
 ip mtu 1400
 ip nat inside
 ip nat enable
 ip virtual-reassembly in
 tunnel source GigabitEthernet0/0.2
 tunnel destination 18.12.19.15
interface Tunnel99
 description T99
 ip address 10.170.170.1 255.255.255.252
 ip nat inside
 tunnel destination 8.22.16.20
interface GigabitEthernet0/0
 no ip address
 duplex auto
 speed auto
 media-type rj45
interface GigabitEthernet0/0.2
 description ISP1
 encapsulation dot1Q 2
 ip address 7.2.2.127 255.255.255.0
 ip nat outside
interface GigabitEthernet0/0.3
 description ISP2
 encapsulation dot1Q 3
 ip address 7.1.0.46 255.255.255.252
 ip nat outside
interface GigabitEthernet0/1
 no ip address
 duplex auto
 speed auto
 media-type rj45
interface GigabitEthernet0/1.10
 description LAN_TO_3750
 encapsulation dot1Q 10
 ip address 10.153.70.2 255.255.255.192
 ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat inside source route-map ISP2 interface GigabitEthernet0/0.3 overload
ip nat inside source route-map ISP1 interface GigabitEthernet0/0.2 overload
ip nat inside source static udp 10.153.70.9 17566 7.2.2.127 17566 extendable
ip nat inside source static udp 10.153.70.9 17566 7.1.0.46 17566 extendable
ip route 0.0.0.0 0.0.0.0 7.1.0.45 10 track 22
ip route 0.0.0.0 0.0.0.0 7.2.2.1 171
ip route 10.10.117.0 255.255.255.0 10.170.170.2 name H
ip route 10.129.122.0 255.255.255.128 10.170.171.2 name K
ip route 10.153.70.64 255.255.255.192 10.153.70.1
ip route 17.5.7.189 255.255.255.255 7.2.2.1 name kb
ip sla 1
 icmp-echo 8.8.8.8 source-interface GigabitEthernet0/0.2
 frequency 50000
 timeout 100000
 threshold 60000
ip sla schedule 1 life forever start-time now
ip sla 2
 icmp-echo 8.8.8.8 source-interface GigabitEthernet0/0.3
 frequency 10
 timeout 10000
 threshold 10000
ip sla schedule 2 life forever start-time now
logging esm config
logging trap notifications
logging facility local3
logging source-interface GigabitEthernet0/1.10
logging 10.153.70.9
access-list 69 permit 10.153.70.9
route-map ISP2 permit 10
 match interface GigabitEthernet0/0.3
route-map ISP1 permit 10
 match interface GigabitEthernet0/0.2
snmp-server community orel RO 69
snmp-server location O
control-plane
mgcp profile default
line con 0
 login local
line aux 0
line vty 0 4
 login local
 transport input ssh
line vty 5 796
 login local
 transport input ssh
scheduler allocate 20000 1000
ntp server 85.21.78.8 source GigabitEthernet0/0.2
ntp server 192.36.133.17 source GigabitEthernet0/0.2
end
Any idea hat is wrong here?
Thanks in advance.
10 Replies 10
Jaderson Pessoa
description ISP2
ip address 7.1.0.46 255.255.255.252  it is correctly?
ip nat outside
ip route 0.0.0.0 0.0.0.0 7.2.2.1 171  < change it from 171 to 11 and test your track again.
if not works, try remove ip sla 2 and track 22 and add it again. Maybe it is a bug.
Jaderson Pessoa
*** Rate All Helpful Responses ***
Hi Jaderson Pessoa,
thank you for the answer.
7.1.0.46 255.255.255.252 - yes it's IP given by main ISP
changed to ip route 0.0.0.0 0.0.0.0 7.2.2.1 11
delete and create ip sla 2 and track 22
nothing changes - still no ping from gi0/0.3
3845#ping 8.8.8.8 so gi 0/0.2
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Packet sent with a source address of 7.2.2.127
Success rate is 100 percent (5/5), round-trip min/avg/max = 28/28/28 ms
3845#ping 8.8.8.8 so gi 0/0.3
Packet sent with a source address of 7.1.0.46
Success rate is 0 percent (0/5)
@ps0000000 hello,
 description ISP2
 ip nat outside
This interface has a vlan 3 configured, this interface is connected directly to ISP device or pass trough internal device?
Because if you cant ping it from itself, router doesn't the problem.
1. Maybe interfaces that is connect from this interface doesn't has the vlan 3 allowed trough the trunk yet.
2. Maybe address is wrong.
Could you confiirm the simple topology?
Thanks in advance.
Jaderson Pessoa
1. ISP connected with my 3750 switch - here is config on trunk port connected to 3845:
interface GigabitEthernet1/0/5
description UPLINKS_TO_3845
switchport trunk allowed vlan 2,3
switchport mode trunk
2. address is correct (here I modify it a little). I can ping 7.1.0.46 from Internet but not ssh.
Does your router has an acl allowing this traffic from external devices?
Jaderson Pessoa
No, full config in first message
ok, try it;
ip access-list extended ssh_allow
permit tcp any host 7.1.0.46 eq 22
and apply it under wan interface that you need access ssh.
Jaderson Pessoa
not helped, even more - when list applied to interface temporarily i have lost connection to internal VPN. Deleting application allows connect again.
well, this ip address "7.1.0.46 255.255.255.252" is caming from your ISP or local firewall?
Jaderson Pessoa
It comes from ISP directly.
