Can't Ping from Router using Static NAT
delano1981
I'm using static NAT on a cisco router and i am unable to ping from the router itself... With static NAT I'm unable to ping any public IP address from the router. Also it is not doing any domain name to ip translations.
I have two public usable IP's one assigned to the nat outside interface and the other assigned to an internal device. There are two static mappings
1) mapping the inernal device to one of the Public IP
2)mapping all internal traffic to the other Public IP assigned to the routers interface
Any assistance is greatly appreciated.
Regarding the one to one NAT (1 mapping the inernal device to one of the Public IP)
Can you config a static nat like below which is best practice and see
ip nat inside source static 10.10.10.4 190.108.199.101 extendable
And regarding name to ip (dns) resolution you have to config the ip domain and name server which i told in my previous post.
Please rate if this helps you...
Naidu.
6 Replies 6
johnlloyd_13
Level 9
Level 9
hi,
kindly post your running config and ping test. thanks!
Which IP you are trying to ping?
if it is nated IP (public) it wont ping from router
And to do domain name to ip translations or visa versa, you need to configure your domain in the router like below...
#ip domain name xxxxxxx.com
#ip name-server ***which you can get from yoru internet provider***
To get clear understnad on the issue, please post your router running config.
Naidu.
THanks for your responce guys... the configs are as follows.
Building configuration...
Current configuration : 1913 bytes
version 12.4
service password-encryption
no aaa new-model
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1 10.10.10.10
ip dhcp pool test
   import all
   network 10.10.10.0 255.255.255.0
   default-router 10.10.10.1
   dns-server 190.124.220.2 190.124.220.3
archive
log config
  hidekeys
interface FastEthernet0/0
ip address 190.108.199.64 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
no ip virtual-reassembly
duplex auto
speed auto
no keepalive
no cdp enable
interface FastEthernet0/1
ip address 10.10.10.1 255.255.255.0
no ip proxy-arp
ip nat inside
duplex auto
speed auto
no cdp enable
no ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 190.108.199.1
ip route 10.0.0.0 255.0.0.0 10.10.10.0
no ip http server
ip nat pool PoolA 190.108.199.64 190.108.199.64 netmask 255.255.255.0
ip nat pool PoolB 190.108.199.101 190.108.199.101 netmask 255.255.255.0
ip nat inside source list 6 pool PoolB
ip nat inside source list 7 pool PoolA
access-list 6 permit 10.10.10.4
access-list 7 permit 10.10.10.0 0.0.0.255
no cdp run
control-plane
banner motd ^C UnAuthorized Users STAY OUT ^C
end
Hi, you can use config below.
1) mapping the inernal device to one of the Public IP (for Web Server)
ip nat inside source list 6 pool PoolB overload
ip nat inside source static tcp 10.10.10.4 80  190.108.199.101 80
ip nat inside source list 7 interface FastEthernet0/0 overload
hth
Muammer
Naidu.
hi,
Here's the thing,  I've tried the PAT, but the device behind the static mapping was ironically showing as coming from the overload address (190.108.199.64). i'm doing authentication on the static mapping and it must show that it is coming from address (190.108.199.101). Also I tried the ip name server and the ip domain name, and thats doesn't do the trick... I still can't ping or do a traceroute from the router. The upgraded config is attached. Additionally, is there any way i can get around using PAT while mapping multiple address to one Public IP?
