CCIEs advice please.
Bilal Nawaz
How should I go about in preparing for the lab? (R & S)
Any recommended bootcamps (UK), lab material for practice etc..?
Would be grateful for experienced answers :-)
I think I should start with a structured daily schedule. But then count out the time I'm at work + travel.
I also heard v5 might be on the way, is this true, and when? If so, should I look to sit the v4 lab or wait for v5
Thank you
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Peter Paluch
Hi Bilal,
I've sent you a PM. Check it out.
Best regards,
Peter
12 Replies 12
Peter Paluch
Hi Bilal,
Best regards,
Peter
Thanks Peter! Really appreciate it.
hello bilal/peter,
sorry if this isn't the right thread but i'm also curious.
is ccie rs version 4 soon to be replaced with version 5? when and could you give any link?
i haven't encountered or read that version 5 will be released anytime soon.
i'm currently "slowly" collecting and building my ccie lab. thanks!
Peter,
We would appriciate if you could send those details to me and John.
THanks
Inayath
John, Inayath,
Check your PM mailbox. Let me know if the message did not arrive (I am not sure if sending a single message to multiple recipients works as expected).
Best regards,
Peter
Hi Peter,
I've received your PM. Thanks for the great advice and will keep them in mind! +5
Thanks a ton Peter.
Inayath
Hello Peter,
much appreciate if you can send me the same information.
many thnaks,
Hi Peter,
Seemed that whatever advises you gave to Bilal did work. Would you give some advises too? I am planning on getting the next CCIE Enterprise.  Thanks
sohail_sarwar
Can you please send me the same as I intend to write CCIE RS
Bilal Nawaz
Wow - 1 year and two months later it actually happened :)
Much credit to Peter - simply awesome guidance.
Bilal
CCIE - 45032
Bilal
Congratulations on achieving your CCIE. This is a very significant event and I am glad for you.
Rick
Rick
