Changing MST and STP priority values
johnlloyd_13
Level 9
Level 9
hi,
i'll be replacing a pair of core switches to a new hardware.
i plan to run a temporary trunk between old and new CSW1 before doing cable migration (to downstream SW and CPE devices) and change MST and STP priority values between old and new CSW1 and CSW2 switches.
would this be a straightforward change and will i lose remote access if i change around these values?
does anyone configure the same and has similar steps/plan?
CSW1-OLD
spanning-tree mst 0-2 priority 24576   <<< CHANGE TO 4096
spanning-tree vlan 1-4094 priority 24576   <<< CHANGE TO 4096
CSW2-OLD
spanning-tree mst 0-2 priority 28672   <<< CHANGE TO 8192
spanning-tree vlan 1-4094 priority 28672   <<< CHANGE TO 8192
pre-configure values below and connect a trunk between CSW1-OLD and CSW1-NEW
CSW1-NEW
spanning-tree mst 0-2 priority 12288
spanning-tree vlan 1-4094 priority 12288
CSW2-NEW
spanning-tree mst 0-2 priority 16384
spanning-tree vlan 1-4094 priority 16384
during the migration of ports/cables from old to new CSW1 and CSW2:
CSW1-OLD
spanning-tree mst 0-2 priority 20480    <<< "FLOAT" MST AND STP VLAN PRIORITY"
spanning-tree vlan 1-4094 priority 20480
CSW2-OLD
spanning-tree mst 0-2 priority 24576    <<< "FLOAT" MST AND STP VLAN PRIORITY"
CSW1-NEW
spanning-tree mst 0-2 priority 4096    <<< LOWER DOWN MST AND STP VLAN PRIORITY VALUES
spanning-tree vlan 1-4094 priority 4096
CSW2-NEW
spanning-tree mst 0-2 priority 8192   <<< LOWER DOWN MST AND STP VLAN PRIORITY VALUES
spanning-tree vlan 1-4094 priority 8192
then remove temporary trunk link between CSW1.
Hello
Why do you need to change the stp priority’s, The old core will still be the active core until you have migrated everything over so why not keep the values as they are?
As for the migration, I would say perform this migration in a 2-step approach,
1- all layer 2 connection (distribution/access)
2- L3
Kind Regards
Paul
hi paul,
i would need to change STP priority values to make way for the new CSW1 and CSW2.
the current  primary STP priority is 24576 and secondary is 28672 so there's no room left for the new CSW since default is 32768 which will make it equal to other downstream/access SW. do you recommend changing all STP priority values on the migration day itself?
