changing native vlan on 3550 switch
fran19422
Hello, I am having trouble after creating a management vlan (99) on a 3550 switch.
I have configured the vlan (99) and given it an IP (192.168.1.100) and a default gateway (my router address - 192.168.1.99).
I can ping to the switch from a PC and vice versa. The management VLAN IP is fine but now I cannot ping to the router from either the PC or the switch.
It seems that just by adding VLAN 99 with it's own IP address has now prevented pings from the switch/PC to the router ?
Due to the fact that I have created a new switch management VLAN with an IP, does this mean I have set up the router as a 'router on a stick' scenario ?
Can anyone offer any advice. Thanks kindly.
SWITCH:
Current configuration : 1773 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname philSwitch
enable secret 5 $1$ilmv$Y.Tk4P.YHv9YW5QUziuLd/
ip subnet-zero
no ip domain-lookup
spanning-tree mode pvst
interface FastEthernet0/1
no ip address
interface FastEthernet0/2
no ip address
interface FastEthernet0/3
no ip address
interface FastEthernet0/4
no ip address
interface FastEthernet0/5
no ip address
interface FastEthernet0/6
no ip address
interface FastEthernet0/7
no ip address
interface FastEthernet0/8
no ip address
interface FastEthernet0/9
switchport access vlan 99
switchport mode access
no ip address
interface FastEthernet0/10
no ip address
interface FastEthernet0/11
no ip address
interface FastEthernet0/12
no ip address
interface FastEthernet0/13
no ip address
interface FastEthernet0/14
no ip address
interface FastEthernet0/15
no ip address
no ip address
interface FastEthernet0/16
no ip address
interface FastEthernet0/17
no ip address
interface FastEthernet0/18
no ip address
interface FastEthernet0/19
no ip address
interface FastEthernet0/20
no ip address
interface FastEthernet0/21
no ip address
interface FastEthernet0/22
no ip address
interface FastEthernet0/23
no ip address
interface FastEthernet0/24
no ip address
interface GigabitEthernet0/1
no ip address
interface GigabitEthernet0/2
no ip address
interface Vlan1
no ip address
shutdown
interface Vlan99
ip address 192.168.1.100 255.255.255.0
ip default-gateway 192.168.1.99
ip classless
ip http server
line con 0
exec-timeout 0 0
password cisco
logging synchronous
login
line vty 0 4
login
line vty 5 15
login
end
ROUTER:
Current configuration : 2815 bytes
version 15.1
hostname phils2801Router
boot-start-marker
boot system flash:c2801-ipvoicek9-mz.151-2.T0a.bin
boot-end-marker
enable secret 5 $1$EoXZ$H4m7dIwwMn/drqZZqoLV./
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
voice-card 0
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
ip address 192.168.1.99 255.255.255.0
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
logging esm config
control-plane
mgcp fax t38 ecm
telephony-service
max-conferences 4 gain -6
transfer-system full-consult
line con 0
password cisco
logging synchronous
login
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler allocate 20000 1000
end
Reza Sharifi
Did you also create the layer-2 vlan on the switch?
vlan 99
name mgmt-vlan
exit
is interface FastEthernet0/1 in up and up mode?
on the router
sh ip int bri
Abzal
Level 7
Level 7
How  router and switch are connected to each other(ports)? Configure port that connected to router as access port on VLAN 99. F0/9 is port connected to PC?
Hope it will help.
Best regards,
Abzal
Terry Cheema
Hi Philip,
If everything was working before and stopped by just adding SVI then turn on ip routing on your switch by running the command "ip routing". You are creating SVI for VLAN99 making it a routed VLAN, but you dont have routing process ON on the switch.
Terry
atef yamin
Hi Philip,
I guess the first question would be if the router is connected to switch. If router is on the same layer 2 vlan as your PC then you should be able to ping it. But by the description of your problem it appears that your router is not connected the same vlan.
Remember that when you configure SVI, the ip address that you give to your SVI becomes the default gateway for the hosts connected to that Vlan.
in this case, since your router has an ip address that is within the same subnet as the SVI, it makes sense to connect the router to the same Vlan and your pinging will work. For other Vlans to be able to reach the router, you should , as Terry suggested, enable IP routing. Creating SVI's would require routing, either use router-on-a-stick or simply enable routing by typing "ip routing" from global configuratoin mode.
Hope that helps.
Let us know how it goes
