Cisco 4500X switch upgradation issue
roshankadam7077
I have upgraded cisco 4500X switches with cat4500e-universal.SPA.03.11.11.E.152-7.E11.bin IOS and now i am unable to take SSH session as we checked found that this IOS is not supporting SSH then what are the options i have with upgrading with K9 ISO.
Leo Laohoo
Upload cat4500e-universalk9.SPA.03.11.11.E.152-7.E11.bin to the switch because the "k9" will support SSH.
is there any other option available?
nextcomm
Could you please share the logs because I just upgraded the switch with this code and SSH is supported? I suggest to check with the line vty configs as I completed the code upgrade I found out the command "transport input none" was set on all VTY lines and I hardcoded it to "transport input ssh". Et Voila!!!
@roshankadam7077
Your image is not supported K9 / cat4500e-universal.SPA.03.11.11.E.152-7.E11.bin
Pleas use / cat4500e-universalk9.SPA.03.11.11.E.152-7.E11.bin
Thanks!
